Wired Control Robot Manual
Intro: Wired Control Robot Manual
1.LEVEL ONE ROBOT (wired robot with 2 dpdt switch).
2.LEVEL TWO ROBOT (Wireless robot with button control).
3.LEVEL THREE ROBOT (Wireless autonomous/programmed robot).
4.LEVEL FOUR ROBOT(solar cell and panel 12v )
5.LEVEL FIVE ROBOT(robot war fight)
6.LEVEL SIX ROBOT (Mobile control robot) by Me
STEP 1: Tools & Components
1.Power Supply.or 12v battery
2.DPDT switch operation.
3.DC Geared Motors
4.Basic motion of Robot
There are following tools are required for this project-
1.Soldering iron
2.Hack saw/ blade
3.Screw drivers
4.Multimeter
5.Pliers
6.Wire stripper
7.Spanner
8.Hammer
There are following components are required for this project-
Battery (12 volt , 4.5 Ah) - 1 nos.
DPDT Switch- 2nos. or 4 nos robot gripper
Ribbon wire strip- 3 meters+
DC Geared Motors 4nos 4x4 or 2 nos 4x2
Chassis(having holes for motor) - 1
box 1
Metal strip 12
Wheels 4 nos.
Castor wheel 1nos(4x2)
Soldering wire - as required
STEP 2: Procedure & Chassis Robot
Before you start making your robot you need a paper plan. Measure length of the motor (excluding shaft), diameter of shaft of the motor, inner hole diameter of the motor. Draw a rough sketch of the base you need to cut keeping in mind the placement of motors and wheels.
Chassis
Chassis is a mechanical assembly for making a 4 wheel drive platform.Where you can mount any controller board to drive your bot. This is just the mechanical chassis, Optionally as shown in the figure you can use 4 DC geared motors, 1 castor and 4 wheels with rubber rings so you can make both variants .
STEP 3: Mechanical Assembly
Fit the caster wheel at position show in above diagram with 1.5-2 inches (approx.) screw. Fit the dc motor into the holes of chassis and couple the wheel by using screw or rubber tube.
STEP 4: What Is Caster Wheel
A Caster wheel is an undriven, single wheel that is designed to be mounted to the bottom of a larger object so as to enable that object to be easily moved. They are available in various sizes, and are commonly made of rubber, plastic, nylon, aluminum, or stainless steel, etc.
STEP 5: DPDT Switches Using Circuit
DPDT Switch Connections for wired control
The wire should solder on metal strip not on switches directly (as shown in fig 3). This precaution helps us if there is wrong connection occurs in circuit. So we can change the circuit by changing metal strip position (fig 4). The procedure is shown in figure below-
STEP 6: Motor Connections
4x4 and 4x2 ! outdoor or indoor !! !
STEP 7: Power Supply &12 Battery
The above circuit shows you how to connect the dpdt switchs to the motors and the 12V supply
and by pressing the switch you can check the direction of the robot and change it accordingly.
thus you are ready with your first LEVEL ONE WIRED ROBOT
you can solar panel 12v without battery !
STEP 8: Using Robot Control
Movements Motor1 (left) Motor2(right)
For moving forward Clockwise Clockwise
For moving backward Anticlockwise Anticlockwise
For turning left Off Clockwise
For turning right Clockwise Off
CONTROLS :-
The following switch positions will give you the respective movement.
L-DPDT switch R-DPDT switch Movement
TOP TOP Forward
BOTTOM BOTTOM Reverse
—nil—– TOP Left
TOP –nil– Right
TOP BOTTOM 360 right
BOTTOM TOP 360 left
77 Comments
biru babu 4 years ago
Sreehyuga 4 years ago
nidhi patel 8 years ago
light 2 bulb in use try robots 5 years ago
increase rpm by increasing amp or voltage.........you can also put some rubber on tires to make them grippe using rubber band will be more than nough
VedanshJ 8 years ago
i used a 300rpm motor version 500TB-13320R..but one of the motor is not working properly..it just jams..and then i need to manually rotate it..what should i do to fix it?..also how to increase the speed of the robot.
take some Vaseline open the gear case then put it inside ......please do bath them with liquid musterd oil before adding vaseline
gaurav.nagotanekar.7 9 years ago
can anyone help my level 1 robo car is not working properly now but it was working fine when i made it..the problem is that when i press right or left switch individually it works fine but when i press them both to go forward it stop i mean it will go few milimeters and then stop for a sec and then again go few milimeter and again stop like that... can anyone tell what is the problem
SEGA550 8 years ago
battery insufficiency and dc motor will have this problemuse stepper motor
increase the amp dwag
UCanCallMe2 9 years ago
SEGA550 8 years ago
30 rpm is best choice for your chassis
my old granny will be faster than that robot .....shit use 100 rpm....more rpm more torque.....while starting to roll
dath 9 years ago
can i use li-po battey instead of lead acid one??
yup but will drain more power google "all about batteries"
adrian.almeida.1441 9 years ago
would 900rpm dc geared motor be suitable!!!!!!
what????? is it tokyo drift 2 or fast and furious 13
nrmhsri 9 years ago
how to fit castor wheel in wired rc car
what is the use castor wheel
any one help me plz................
that is the same quesstion turning up to me too
MithunK19 6 years ago
Sajith Sasi 7 years ago
