Wireless Arduino Remote Camera Trigger
Intro: Wireless Arduino Remote Camera Trigger
Wired camera triggers typically work by acting as a switch. Camera circuitry operates at 3.7V (a single Li-Ion cell, i think) so you can either complete a physical switch to trigger the camera shutter, or you can apply 3.7 volts across the two contacts to trick the camera into firing. In this project, I used an Arduino to apply the 3.7V to activate the camera trigger through my old mouse camera trigger.
The Arduino Fio was controlled over XBee radio modules (efffective range of 250 feet...? ish...). I wrote a simple program on my laptop so that when i clicked in a window, it sent a command to briefly apply voltage to an I/O pin on the Arduino. It could also be automated, so that the Arduino is an intervalometer.
5 Comments
jack002 11 years ago
WinstonMakes 11 years ago
You "focus" button will simply short "ring" (middle contact) to "sleeve" (ground). Your "shutter" button will connect "tip" (self-explanatory) to "sleeve". (I may have mixed them up...)
You could go to radio shack and spend $$$ on a custom breakout audio jack... or just get a headset for older smartphones/cellphones and splice the cable yourself.
Just get a digital multimeter and see which wire goes to what part of the jack.
No need for resistors or anything in between, you're not introducing an external power source, unless you're using an Arduino.
diy_bloke 12 years ago
Also I do not understand what you mean with 'remotely via my laptop'
You mean to say that you need a modified mouse AND and Arduino AND yr laptop to take a picture?
A little bit more description would surely help
WinstonMakes 12 years ago
But yea, thanks for giving me a heads up on my negligence.
