Wireless Mic to Guitar Hack
Intro: Wireless Mic to Guitar Hack
Wireless guitars are great, without cables to trip on the life expectancy of an energetic guitarist is greatly increased. However, they are expensive, way more expensive than wireless microphone systems. In fact, if you're like me, you might happen to come into a wireless microphone system for free. Using it for your guitar is a ultra-simple hack that almost anyone can do in less than an hour.
STEP 1: Tools and Materials
Tools required:
- Soldering iron
- Wire strippers
- Drill and 3/8" bit
- 1/2" wrench
- 1/4" guitar jack
- Solder
STEP 2: Disassemble
Before you rip into the mic, test that it works! It could save headaches later.
Most of these mics just screw together to allow for the occasional cleaning. Twist the top off and pull out the microphone-holding center piece. Cut the wires as long as you can so that there is enough slack that the wires don't break when the microphone is screwed back together. If there isn't enough you may need to extend them a few inches.
STEP 3: Drilling the Top
Using the 3/8" drill, drill a hole in the top of the microphone, through the mesh. Using a drill press and vice is best for this, since it is likely to snag on the mesh. Do be careful.
Once the hole is drilled, apply some tape around the inside, on the top of the mesh, and beneath. Its likely that if the guitar jack makes electrical contact with the housing of the mic, it won't work properly. I had this problem and I solved it with tape.
STEP 4: Wire the Jack
Strip the ends of the two old microphone wires and solder them to the lugs of the 1/4" guitar jack. I guessed that the red one was signal and green one was ground, but I don't think it matters. If there is an issue, try flipping the wires.
STEP 5: Re-assembly
Push the jack up into the microphone head and attach using the included washer and nut. Tighten with the 1/2" wrench.
Screw the head of the mic back onto the body. Plug it in and test it out!
STEP 6: Bonus Step: Belt Loop
If you've got some rubber, sheet metal or leather around, you can make a simple belt loop for the mic so that the antenna is exposed. It's likely it won't fit in your pocket very well.
- Cut a 5" strip of rubber, punch two holes in the ends
- Cut a strip of aluminum sheet metal
- Drill a hole in it
- Bend it over an edge into a tight U shape
- Assemble with a screw and nut
STEP 7: Ready to Use!
Jack in, plug in the receiver, and hit the on switch, and your amp will roar to life with musical power. I found that I had to keep my guitar below about 3 on the volume knobs otherwise there was distortion, the pickups in a guitar create a more powerful passive signal than the microphone element must have.
33 Comments
MahulC 7 years ago
But battery issues are there..
How to increase the battery life.?
mattthegamer463 7 years ago
MahulC 7 years ago
I charged it with a powerbank.
But fm mic is very easy to fit so can i connect any additional batteries with it?
You can connect more matching batteries in parallel with the original battery to increase the battery life.
Rhitosparsh 7 years ago
First of all, an amazing hack!
I have a question.
http://www.amazon.in/gp/aw/d/B017EO4ITI/ref=pd_aw_sim_sbs_267_of_38?ie=UTF8&dpID=41QCRosrmEL&dpSrc=sims&preST=_SL500_SR100%2C100_&refRID=1H4SKHH53NKBFRGKP9RY
Can I use the above mic's transmitter, if I use a 1/4' male to XLR male jack?
Regards.
kalkeriakshay 7 years ago
you saying about the switch and in line that is correct
Well, I was thinking, isn't there a less destructive way around, by which I can use it both as a mic as well as the guitar wireless transmitter?
If you can find room for the guitar jack elsewhere, you could put a switch in line with the microphone, and add the jack in parallel with the microphone/switch combination, so when you plug in the guitar and flick the switch to OFF it will take the guitar input, but when the guitar is unplugged and the switch is set to ON you'll have the mic.
Only issue is there isn't much room in the tip for that. You could make the guitar jack completely external if you wanted.
I was thinking a little differently. I thought I'd place the input jack a bit lower down the body. Then I'd use another 1/4' jack to connect it to the wires that come out of the actual microphone. This way I'd be able to plug in both the mic or the guitar, whichever I wanted. However, I'd need another mesh to be able to use the device as a microphone.
The top part screws right off, so you could probably find a way to make it swappable in that area.
adrian.palusinski 8 years ago
I think the best idea would be to add the step down impedance transformer (as guitar is hi-z device ) right after the input jack in mic enclosure. This way your guitar should volume shouldn't need to be dialed out anymore.
I'm talking about sth like this, it's kinda penny-sized.
http://www.neutrik.com/en/accessories/nte10-3
I suppose you wouldn't need the low->high impedance matching transformer after input of the receiver as, while it has jack plug, it should be already hi-z.
Hope that would help.
Best Regards,
Adrian
mattthegamer463 8 years ago
oh I see. There's one more thing i think about - if it was condenser and had bias voltage on it then transformer would isolate pickups from being biased and therefore there would not be disturbance in their magnetic field. (I think there could be some) .
Silvester Jay 9 years ago
mattthegamer463 9 years ago
In short, it can be done, but with a wireless transmitter the volume may be too low. I have plugged my guitar into my PC mic port before and it works, but the sound quality is very bad and the volume and microphone boost must be maxed out to hear anything.
The reason this particular hack works is because this wireless microphone used a simple condensor microphone and not an electret, so the signal levels from the condenser and the guitar were of similar power.
cdpoloz 9 years ago
Hi, pretty awesome hack! Do you think it could work with low frequencies from a bass guitar?
Should be fine. It might be filtered to minimize frequencies at 60Hz and below though.
cdpoloz 9 years ago
Ok! Hope to test it asap and I'll let you know, thanks!
jdelgadillo1 10 years ago
