Wood Burning Lichtenberg Figures
144,972
279
47
Introduction: Wood Burning Lichtenberg Figures
About: Love woodworking and all things electricity!
Wood burning can add a unique element to your wooden creations. But using a simple wood burning pen set can be challenging unless you have lots of artistic talent (I do not that's for sure). Wood burning with high voltage is a unique way to mark your projects and add a bit of flair. The Lichtenberg figures are sure to make your piece stand out. Whether the figures are the main attraction of the piece or just an accent, it's totally up to you.
In this Instructable I'll detail:
  • Risks
  • Materials
  • Process
I'll tell you everything I know, but this is by far not a defined science. Once you've gotten the hang of it, feel free to safely experiment with different types of wood and concentrations. Regardless of your familiarity with wood burning with high voltage, please watch Doublereno's videos on Youtube(www.youtube.com/doublereno). He is safe and does an excellent job with explaining his process. Additionally, please read through this whole Instructable before starting so you know where the steps are leading to.
Let's get started!
Step 1: Understand the Risks
THIS PROJECT IS DANGEROUS.
Please do not attempt this project until you are fully aware of the dangers and necessary safety measures. People have been seriously injured and killed by doing this. Electricity is no joke, 12,000V and 35mA produces a painful shock and can lead to serious consequences.
Because of this, I follow, and advise you to follow these safety precautions:
1: Do not burn alone. If something happens, it is vital that someone else is there to help you in case you've been hurt.
2: Place wood on an insulated surface. This will ensure that the electricity flows only through the wood.
3: Wear insulated gloves. You always want to limit how much you touch the rig whether its on or off, but when you do, wear protective equipment just in case.
If you have any health problems, a shock of electricity could turn into something deadly. Please do not attempt this project unless you know the risks.
Step 2: Gathering the Materials
I'll assume you don't know too much about wood burning with Lichtenberg figures, but I'll spare you the science. I'll spell out the process quickly here so you know what the materials are for, but don't worry, I'll explain it in detail when we get to the process.
1: Neon Sign Transformer (NST)
NSTs are used to provide the high voltage needed to burn across the surface of the wood. The electricity from one probe is trying to reach the other probe and burns across the surface as it tries to find the path of least resistance.
I used an Allanson SS1235ICH 12000V 35mA NST. High voltage will create more branches and better looking figures and the lower amperage will help keep you safe.
2: Alligator Clips
These are used to help transfer electricity to the probes and give you something safe to hold. Beware that at such high voltages, the current can jump the alligator clips. That's why its incredibly important to use proper safety measures.
3: Probes
I used brass rod which I sanded down to a point as well as copper coated nails. In a few tests I couldn't tell any performance difference, but many people use brass rod.
4: Insulating Gloves
When handling the alligator clips I used 12,000 volt insulating gloves just in case. I would highly recommend you do the same. Though they can be uncomfortable, they can save you from a dangerous shock.
5: Prep Materials
You'll need baking soda, a table spoon, measuring cup, a mixing cup. And a paint brush, I would recommend about 1.5" brush.
6: Clean-up Materials
You'll need paper towels handy, as well as a hard bristle brush and some sandpaper (between 600-1500 grit).
7: Wood
Of course, you'll need the piece you plan on burning. Before you burn anything nice that you've made, I would find some scrap of the same wood and test the burning to make sure you work out the kinks before charring and ruining a piece you've made. When it comes to wood, a solid choice is Poplar. Most soft woods will work well, but the grain tightness and other factors may change how the wood reacts to the mixture and high voltage.
Step 3: Prep the Wood
We're getting closer to the fun stuff, I promise. But these steps will determine how well the wood burning turns out so follow them carefully.
1: Sand the wood. Once you burn, you're going to want to limit the amount of sanding in order to preserve the detail of the figure. The grit is up to you, but I normally sand to around 800 grit.
2: Mix the solution. Dry wood itself will not conduct electricity, so we have to make a conducting solution for the surface of the wood. Stir and dissolve 1 Tablespoon of baking soda to 1 Cup of warm water. This ratio is flexible, experiment with your scrap piece and see what works best.
3: Apply the solution. With the solution fully mixed, dip the paint brush in and apply the solution to the surface of the wood. The wood doesn't need to be swimming in the solution, apply it, gently dab the wood to soak up any excess. Leave the wood for about 5 mins to soak up the solution. Right before you're ready to burn, apply a light coat of the solution and wipe up the excess, now we're ready to burn!
Step 4: Burn the Wood
BEFORE BURNING, PLEASE WATCH SOME OF THIS VIDEO:
^BEFORE BURNING, PLEASE WATCH SOME OF THIS VIDEO^
This was made by the excellent "doublereno" and though some details in his burning rig are different then mine, his process is exactly the same. If any part of my written explanation is unclear, doublereno's videos are a great resource.
Here's the fun part. It's also the dangerous part so please be careful.
Place your probes a few inches apart, turn on your NST, and watch the figures burn and crawl towards each other. Rest the alligator clips on dry pieces of wood to balance the probes so you don't have to hold them while the electricity is coursing through. Feel free to turn off the NST, and move the probes to create a different branch.
The heat from the burns will begin to dry out the wood, once the NST is turned off, apply a light coat of the mixture to keep the figures crawling at the right speed. Too slow and the figures will be too crowded and just look scorched, too fast and it won't branch. Keep practicing and experimenting to find the perfect mixture and amount to apply. If the wood is too dry, it won't burn. If it's excessively wet, it won't burn. And somewhere in between there's the happy medium where the wood, concentration, and application of the mixture create the perfect burn speed. Its tough to get it right the first time so definitely plan on using some practice pieces.
Step 5: Clean the Figures
Once you're done burning, take the wood to a hose or deep sink to clean out the figures. Use the hard bristle brush and the flowing water to scrub the figures, removing char and showing more detail in the figures. Keep scrubbing the figures until no more char is removed.
Let the wood dry a bit and take sandpaper between 400-1000 grit and sand any burns. Be careful not to sand the figures or you risk sanding away the fine details of the burn.
Step 6: Enjoy!
Enjoy what you just made! Please feel free to comment on this Instructable with questions, successes, or info you'd like to share. This is also my first Instructable so let me know how I can improve for future projects, thanks!
I'd like to thank the Georgia Tech Invention Studio for helping with this project. As the largest student-run maker space in the country, they supplied miscellaneous items, space, and funds for this project. As a student at Georgia Tech, they've allowed me to pursue my passions and create some really amazing things. I highly recommend anyone in high school to look into GT because of the incredible maker culture they have. If this is a project you love, the Invention Studio is a place you'd love to be.
14 People Made This Project!
  • Stone, Concrete, Cement Challenge
  • Pets Challenge
    Pets Challenge
47 Comments
DrFG49
DrFG49
Tip 4 months ago
As someone who's done a few of these now, whilst you *CAN* assemble a kit from scrap parts, bear in mind that you're using thousands of volts and a solution designed specifically to allow electrical conductivity through a medium (wood) that's usually a pretty good insulator. So BE CAREFUL. I have no affiliation with this guy other than the fact I bought his kit and it works well - Conestogaworks.com . And even with a purpose designed kit designed to be safe, the BE CAREFUL bit stands. You can easily set your workpiece on fire - you may well want to! - but with that comes another big dose of BE CAREFUL, be aware of your surroundings and have water/fire extinguishers available.
Boonetang09
Boonetang09
Question 5 months ago
Can you preform this on treated wood?
elexis.renfro
elexis.renfro
Question 7 months ago
We use a NST to do fractal burning but it doesn’t seem the designs go very deep. Not enough for filling with colored epoxy. How do you get the Wells deeper??
georgelogan92
georgelogan92
Answer 6 months ago
Hi, my father and I do this for fun and we just add potassium nitrate to the water and soak up a rag and apply the solution that way ,and then let the wood sit for a couple minutes then do it
elexis.renfro
elexis.renfro
Reply 6 months ago
Do you use potassium nitrate with baking soda or just PN on its own in the water?
georgelogan92
georgelogan92
Reply 6 months ago
Just on it’s own
joeking4927
joeking4927
1 year ago
First burn yesterday what to use clean out burns to add epoxy?
georgelogan92
georgelogan92
Reply 6 months ago
try a paint brush
brandondiehl163
brandondiehl163
6 months ago
I wonder if you ever thought you could be held liable for posting this information on the internet? STOP DO NOT ATTEMPT. THIS TYPE OF ART WORK AND METHOD WILL KILL YOU. my longtime best friend was using this method 3weeks ago and something went wrong and he was elelectrocuted fried to a crisp the fire dept had to come cut the power and put him out . There was a charred body while the structure suffered little damage... Mark Burr was a good friend he made fatal mistakes . Be very aware of what your doing....i warned you
...just saying ...its very dangerous
maryann121354
maryann121354
8 months ago
Do jumper cables work as the NST
petmjohn
petmjohn
1 year ago
First I would like to say, thank you for posting this.
Second, if you are needing some inspiration, especially the guy doing the guitar, look on etsy and search Instagram for "licktenburg"
Third, I will be doing some of this once I have my bentwood rings up and selling.
On another note, I am wanting to see about doing it with leather.
NeilRG
NeilRG
1 year ago
I'm a bit concerned that you did not wear the rubber gloves you advocated, and that someone who might not be a native English speaker might try this based only on your pictures. It might be a good idea to rig up a relay and foot switch on the AC supply.
The results are quite stunning .
SpeR1
SpeR1
Question 2 years ago on Introduction
I bought a neon sign transformer from amazon10,000 volts 35 milliamperes , followed the steps and nothing happened , thought the transformer was bad so I returned it and got another one and still nothing. Any idea what I could be doing wrong? No sign of current at all. I moved the probes closer , further apart , more solution different alligator clips etc.
Jkroat11
Jkroat11
Answer 1 year ago
Check your connections, the nest xfmr have a switch on them on/off it may not be easy to see. Check those first, and let me know what you have.
sld7531
sld7531
Reply 1 year ago
I'm not sure what the issue may be. It may be a type of short circuit protection where the current will shut off to protect the transformer and user. Potentially try a different concentration? As well as soak times? Best of luck.
rabiaah111
rabiaah111
2 years ago
Hi,
Your explanation was and is the best until now among the many articles and videos i have seen. Even the machine you have build looks simple and clear, although i wished that you would have done a step by step video for this. Hope you consider that, it will teach us also the way you have build it with maximum measures to make safe. My question, where did you buy your alligator clips please?
Thank you in advance and i really hope that you do the step by step video how did you construct this machine.
My best wishes.
Zappa
sld7531
sld7531
Reply 1 year ago
Thanks for the kind words- if I have time to make a video I will. I ordered basic alligator clips off of Amazon but I would suggest getting some that are larger since it will be easier/safer to maneuver.
demabe
demabe
Reply 1 year ago
Hi Folks!
DMGlass
DMGlass
1 year ago on Step 2
Thanks for sharing these instructions, can’t wait to tru it out
