Cheap Yet Chic Wood Lath Wall
Intro: Cheap Yet Chic Wood Lath Wall
Looking at materials differently can ultimately yield some fantastic room decor on the cheap. For example, a few bundles of inexpensive wood lath, some stain, a few nails, and you've got yourself a stylish wall for less!
STEP 1: Before
This poor guest bathroom has seen so many changes and yet none of them ever seemed quite right. That is, until I spotted some $15 bundles of wood lath at the home improvement store.
After some quick math which was hard as math is no longer a strong suit, I grabbed two full bundles and a couple extra loose pieces for this particular project.
STEP 2: Staining
I tested out various stains and didn't hit upon the look I wanted until I thinned out the stain with some paint thinner. Now it's a custom color! But really, the color at full strength was too strong.
I stained each wood lath individually by hand. Yes it did take a while but in the end it was totally worth it.
STEP 3: Time to Install
This bathroom is not used very often so I didn't seal the wood but it can most certainly be sealed for ease of cleaning and moisture repellence.
Right off the bat, I ran into my first installation dilemma, the toilet water connection. No big deal, I cut around it accordingly.
STEP 4: Spacing
I used a paint stir stick to create a gap between the wood lath strips for several reasons, mainly for a cool look but also to give the wood room to do its wood thing.
I merely nailed the lath strips onto the wall with a brad nailer.
STEP 5: Going Up
I was sure to cut the wood lath strips into different lengths so that the pattern would be offest and not the same all the way up.
STEP 6: Obstacles
Going around the switch and outlet was a bit tricky but as you can see, I had a built-in guide of old paint to show me the way.
Be sure to swing by the blog to find out how I resolved the new difference in depth with the switch cover plate.
STEP 7: Last Step: Enjoy
For less than fifty bucks, I had a brand new wall, a high-end chic look at a fraction of the price, and all sorts of textural excitement.
20 Comments
rizoz.vallarta 3 years ago
Flipping the Flip 3 years ago
bryans workshop 4 years ago
Flipping the Flip 4 years ago
charlessenf-gm 4 years ago
Lathe strips appear to be close to three feet in length - though I didn't see any dimensions listed - and about a quarter of an inch thick and over an inch and a half wide.
Since wall studs are likely 16" O.C. it would have been good practice to locate them and nail the strips accordingly. Such an approach, in conjunction with a bit of construction adhesive here and there would have been preferable to 'shooting' brads in drywall.that conceals water pipes and electrical wires pneumatically/forcibly.
As one recently 'in the market'. for another residence, I can tell you that these projects (as so often done by 'flippers') look great in the MLS photos but work to diminish the value of the home once close inspection reveals such shortcuts as excused within this project's description.
There are 'extension rings' available for electrical boxes (the original box appears to have a 'mud ring' in place) to allow for the additional thickness of the wood covering without 'opening' the electrical box which, as I understand it, is intended to be closed up if not sealed.
Hey, the project looks nice, and the intent is not to denigrate the project. Rather to caution folks thinking of attempting something similar that poorly executed 'projects' are more likely to reduce the value of a property then enhance it. Think "Buyer's Inspection/Inspector's Report."
As this is not meant to be permanent, it’s meant to be easily removed, I didn’t tack into the studs nor use adhesive. For sure, if someone were doing this more permanently those are advisable steps, knowing that adhesive will damage the wall upon a later design decision change. So, as such, I’m not excusing shortcuts, as you state. I don’t step into projects frivolously.
Ya know, I think a lot of this depends on who’s doing the installation, why, and how. Sure, flippers are not always known for quality work but that shouldn’t deter someone from trying any project. Folks should research, learn, and try new things, in my opinion. If we all do things, or not do things, driven by the mountainous amount of concerns regarding anything, we’d all be hermits in very boring houses.
This is likely my error in presenting a project meant more to inspire ideas and creativity rather than as a cut and dry how-to.
rsgrillo 4 years ago
Do you vacuum it, brush?
sharpstick 4 years ago
notbad 4 years ago
WolframMaria 4 years ago
jessyratfink 4 years ago
acheide 4 years ago
AussieAlf 4 years ago
