Introduction: Wood Storage Cart / Carrito Organizador Madera
Hello Makers!
I'm glad to share with you this wood storage cart made for our educational MakerSpace!
It's common to have a lot of wood scraps so it's very important to have an organized workshop for security matters, so I hope you find this project useful.
Note: I see a lot of projects where people use circular saw machines or else, but we don't have a lot of tools so my design is easy-to-assembly.
Hola Makers!
Encantada de compartir este carrito organizador de madera para nuestro MakerSpace educativo!
Es muy común tener muchos sobrantes de madera y la seguridad es primero por lo que es importante mantener el taller organizado, espero les guste el proyecto.
Nota: Muchos proyectos que encontré usan sierra circular o máquinas complejas que nosotros no tenemos, por lo que me enfoqué en el diseño de un armado simple.
- 2 pine plywood boards of 15mm (122cm x 244xm) at HomeDepot (i asked for the cuts)
- 4 wheels (size or model of your choice)
- 1 bag of wood screws #8x1"
- Drill
- Drill bit 5/32
- Measuring Tape
- Pencil
- White or yellow glue
Materiales:
- 2 paneles de triplay de 15mm (122cm x 244xm) pedí los cortes en la maderería.
4 llantas (tamaño a su gusto)
1 bolsa de pijas para madera de #8x1"
- Taladro
- Broca para madera de 5/32
- Flexómetro
- Lápiz
- Pegamento blanco o amarillo
Step 1: Sketch or Model Your Design/ Dibuja O Modela El Diseño
I got inspired by "Tamara's Scrap Wood Storage Cart" found on youtube but I didn't have enough budget or machines to do it similar, so I recommend to make your own design. I used Fusion360 to model the idea, I only wanted to use 2 plywood boards with the 3D design I was able to analyze how much material will be used or how It will be assembled.
I recommend you to first sketch or model if you can the idea depending on materials or budget you may have.
Or you can download the PDF for the plans!
Me inspiré en el proyecto de Tamara encontrado en youtube, pero no tenía tanto presupuesto, materiales ni máquinas para hacerlo tal cual, por eso elegí primero modelar en 3D mi diseño para calcular la mejor distribución de piezas, el armado y aprovechamiento de materiales ya que sólo quería utilizar uno o dos paneles de triplay.
Yo recomiendo que primero hagan su diseño ya sea en boceto o 3D dependiendo de su presupuesto o materiales. O pueden descargar el PDF con el plano.
Step 2: Think and Ask Your Cuts / Analiza Y Pide Tus Cortes
My local wood store offers the wood cutting service, so I asked them for less cuts than what I designed first (You can see the actual cuts in PDF attached file) because I only wanted to use 2 plywood boards and use a piece of it for another wood project.
You can either call this stingy or clever for using less material. (This project was low budget)
La maderería local ofrece el servicio de corte de la madera, por lo que modifiqué el diseño para menos cortes y sólo comprar 2 tablones completos además de poder usar el sobrante para otro proyecto.
Pueden descargar el PDF con la imagen de cortes
Llámenlo ser tacaño o astuto por usar menos material pero recuerden que este proyecto es de bajo presupuesto y poco tiempo de armado.
Step 3: Time to Put Together! / Hora De Armar!
It took me 1hour to build this wood cart (time-lapse video), think first which pieces will be together to make it less complicated, specially if you're by your own.
Assembly tips: If you can always have 2 drills is better: one with the drill a bit thinner than the wooden stem, the second one with the cross tip to screw the stem, this is very practical and effective.
Me tomó 2 horas armar el carro de madera, piensen primero cuáles son las mejores piezas para armar primero especialmente si lo arman solos.
Truco de ensamble: Si pueden tener siempre 2 taladros: 1 con la broca más delgada que la pija para guiar, el segundo con la punta de cruz para atornillar las pijas es muy práctico y efectivo.
