Wooden Comfy Chair IPhone Dock
Intro: Wooden Comfy Chair IPhone Dock
My phone works hard for me. It takes pictures, gets me pictures of what my friends are eating, twitterates, and sometimes even makes a phone call. So I figured that it deserved a nice comfy spot to sit in when it was on my desk. It was certainly better than just tossing it on a pile of tools like I usually did.
STEP 1: Materials
OK, let's make this thing! Here's what I used
- 1/4" plywood (just a couple square feet)
- 1/4" neodymium magnets
- Elmer's Carpenter's Wood Glue
- Gorilla Glue
- stain
- clamps
- sandpaper
- USB charging cable
The pieces were cut out with a laser cutter, but the same thing can be done by hand as well.
- Gorilla Glue
- stain
- clamps
- sandpaper
STEP 2: Cut the Pieces
Like I wrote in the last step, these pieces were cut with a laser cutter so it was quick and precise. Just use the attached files and you're good to go.
If you don't have a laser cutter, which you probably don't, you can use one at a local TechShop, or get them cut at Ponoko.
Barring that, you can always do it by hand as well. Yes, it will take a lot longer, but it's an option.
STEP 3: Glue!
Now is the time for lots and lots of Elmer's Carpenter's Wood Glue and clamping. You can glue the pieces together a few pieces at a time or go for it all at once, it's your choice.
In this chair, I used this arrangement for each half:
Left Side:
- 2 arm pieces
- 4 regular seat pieces
- 1 notched seat
- 1 notched seat w/ holes for magnets
Right Side:
- middle piece (in 2 parts)
- 2 notched seat pieces
- 2 arm pieces
Left Side:
- 2 arm pieces
- 1 notched seat
Right Side:
- 2 arm pieces
STEP 4: Magnetize
With both sides glued up, it's time to add the magnets that hold it together. I used neodymium magnets that are 1/4" diameter and 1/8" thick. Since the pieces were 1/4" thick, I used two magnets for each hole so that it would be easier to keep the surface flat.
Inside each hole, I placed a drop of Gorilla Glue and pressed the pair of magnets in. Since Gorilla Glue expands, check in on it a few times in the first 10 minutes. If the expanded glue pushed the magnets out, push them back in and wipe off the excess.
STEP 5: Sand and Stain
With the pieces good to go, it's time to clean everything up and stain it. And by cleaning, I mean using sandpaper to get a smoother finish on the outside.
With that done, wipe up the whole thing and apply a couple coats of stain.
STEP 6: Use Your New Comfy Chair
With the stain completely dry, add in the charging cable by pushing it into the track. It should fit in without much trouble at all.
With that in, let the magnets grab the pieces together and put your phone in!
23 Comments
RobB45 1 year ago
PikachuSonikkuCUTIES 9 years ago
vclapper 9 years ago
I did this little project with a band saw. It took like 8 hours to do everything but it ended up surprisingly smooth. Definitely worth it. Great idea!
حناين 9 years ago
Jonzy---1306 10 years ago
raydanial 10 years ago
Mythbuster425 10 years ago
fungus amungus 10 years ago
CandyLV 11 years ago
devalpha_1 11 years ago
Jayefuu 11 years ago
abente 11 years ago
abente 11 years ago
Winged Fist 11 years ago
joshmt2012 11 years ago
god.favored 11 years ago
DoctorDv 11 years ago
-Doctordv
fungus amungus 11 years ago
canucksgirl 11 years ago
