Wooden Flower Pot
Intro: Wooden Flower Pot
Have you ever wanted to make a wooden flower pot? Of course you have and were here to teach you how. Although the project may take some time, it is fun and easy and you'll be happy with your final result.
STEP 1: Materials
You will need to find or purchase several materials in order to complete this project. You will need 2 or 3 sticks or planks of wood like in the images above. You will also need a tool like a saw to cut it into equal pieces. The last three materials you will need are glue that works on wood, wire to hold it all together, and a base of wood to build on.
STEP 2: Step 1
The first step you will need to take is cutting the large pieces of wood into separate pieces. This will require a saw, ruler, and the pieces of wood.
STEP 3: Step 2
Step two will require you to glue and string it all together. You will stack the wood in a specific pattern in order for your final result to look the way it should. This will require the cut prices of wood, Glue, the base, and the wiring to string it all together.
STEP 4: Step 3
The final step will be waiting for the glue to dry and checking to make sure that it is wired close together so the final result is held tight together. You will now be left with your final result.
tomatoskins 9 years ago
Really cool idea! Thanks for sharing!
