Wooden Leather Burnisher
Intro: Wooden Leather Burnisher
After doing some serious leather work, I wasn't happy with the cut edges on what I was making. Normally I don't burnish edges because the sealant I use soaks into the edge and makes the edge very water proof. However for this particular project I am making I felt it needed it. I read on a few sites that burnishing can take hours sooo I did some thinking and thought " why not make a burnisher that fits on a Dremel, a fast burnisher!!!". I then did some YouTubing and found a video with a guy using one he bought. I designed mine differently to take three different sizes of leather. 1-2mm, 3mm and larger. It works great and takes only a few minutes to burnish quite a lot of leather. I hope you guys enjoy.
STEP 1: Things You Need
First I bought a timber curtain rod end and cut the base sides off so that it does not roll away when put on a bench or piece of marble. It will look like.. . . .. ... LOL ...UM well ya know. Next get some 3mm or 1/8th braising rod. This is very cheap from a hardware store, I had some laying around so I cut a small piece about 50mm or 2 inches.
STEP 2: Drill Base
Next Put a 1/8th or 3mm drill in your Dremel and make a hole as straight as you can in the base of the curtain rod.
STEP 3: Mix Glue
Next mix up some Araldite and swirl it around the braising rod and put it in the base even drip some in.
STEP 4: Let It Dry
Let this sit for 24 hours - don't jump the gun on this step. I also filled a crack that was in this timber with the glue.
STEP 5: Trim Braising Rod
Then with wire cutters, cut the base off the rod so it fits most of the way into the Dremel drill, then sand smooth.
STEP 6: Cut Lines
Next use a hacksaw to cut in lines on the timber where you want to have your grooves. Do this by turning on the Dremel and slowly touching the hacksaw teeth to the timber bit you have made.
STEP 7: Shaping
Next use the hacksaw as a lathe tool to shape the timber while the Dremel is going. You could use a rats tail file for this if you have one or even really heavy-grit sandpaper. I turned the hacksaw on an angle to open up the grooves.
STEP 8: Sand It
I then I used sandpaper to clean the grooves out. Follow this with 600 grit wet and dry paper to smooth out the grooves and surface. I changed this later by opening the grooves to be more concave, although it created a very cool V shape on the edges at first.
Shape it according to what you want your leather edges to look like.
To use this, wet the leather with water and then burnish. No products required.
21 Comments
across leather 8 years ago
ALD3 9 years ago
PowellMade 9 years ago
Thanks for the input! Yep definatly agree burnt edges arent nice to look at.
onemoroni1 9 years ago
This makes me want to get into leatherworking that I have been considering to make my own belts. Now I have a major process simplified in your instructable. I'm not sure what burnishing does. Is it a way of sealing the edge by slightly burning? Do you use any preparations? Thanks for your clever instructable.
eruger 9 years ago
It not only is much better for look, feel, and usefullness, (it's one of the big differences between professional work and everything else), but it's also more durable, especially after you've added the edge dressing, because the most vulnerable part of the leather has been made tougher, less absorbent and snag-resistant.
eruger 9 years ago
Great idea and great istructable! Question: Isn't delrin considered even better for burnishing leather? It's just as machinable, and tougher.
robolimbo 9 years ago
Great burnisher! I"ll turn one on my lathe right away! Great instructable! I'm going to put mine on a drill press so I can use two hands to hold the leather.
repurposed 9 years ago
What a smart idea! Thanks for sharing.
boatingman 9 years ago
Doedskvad 9 years ago
Is the burnisher also safe for personal application? ...just asking ...for a friend.
Fikjast Scott 9 years ago
well done, nice photos
The Rambler 9 years ago
This is awesome and I will definitely need to make one for myself.
P.S. I think traditionally you would still use some form of sealer in conjunction with burnishing. From what I've read it seems the best method is to coat the edge in a sealer, such as gum tragacanth, and then burnish it. The heat from the burnishing motion heats the gum trag and bonds it with the leather creating a smooth sealed edge.
remington700links 9 years ago
Seen a lot guys using these on the net,some secret wax mixture for great edges.
peppypickle 9 years ago
really well done, thanks for the photos and instructions! great 'ible!
hjjusa 9 years ago
Bubinga hardwood makes a really good burnisher, just smooth it down to 150 grit sandpaper.
