Introduction: Wooden Lock Puzzle
This simple wooden lock puzzle will challenge your mind. You are given three wooden blocks. The goal is to assemble them in the cross pattern shown.
I started this as an "I made it" project but since I changed the size and building techniques, I thought I would include detailed build instructions. The original versions are shown here and here. Also, I think this was pretty easy to build. However, it you are not up to it, similar version can be purchased from online.
This video gives away the solution. Skip it and don't go past Step 10 if you would like to try to figure it out from the drawings.
Step 1: Tools/Materials
Tools:
- Table Saw
- Router
- 3/8" Roundover Router Bit
- 3/4" Straight Router Bit
- Band Saw
- Pencil
- Calipers
- Sander
Materials:
- 1x4 by 20" Long
- Paint/Stain (optional)
Step 2: Drawings
This is the top level drawing. Detailed part drawings are included for the three pieces.
Step 3: Blocks
I used a scrap piece of 1x4 cedar for the blocks. I started by cutting it down to the desired width (2.25"). Note that I cut a board long enough to make six pieces (vs. the required three). Knowing myself, the extras come in handy when I mess up, which is quite common.
Step 4: Rounded Edges
I used a 3/8" roundover bit and routed the board from both sides. This was done for both ends.
Step 5: Cut Blocks
I set the table saw to 6" and sliced the board down. Edit - This is the wrong way to make cuts. Although easy, you should not use the table saw rip fence as a guide for cutting wood to length. The wood can become trapped between the fence and the saw blade and pose a kickback hazard.
Step 6: Block 1
With the router centered on the workpiece, I cut the groove with a 3/4" straight router bit to the dimensions shown.
Step 7: Block 2
Cut the same groove for the all three parts. The only difference is the notch cut in the center. I used a band saw for this cut.
Step 8: Block 3
Same as before except I used the 3/4" router to make the additional notch.
Step 9: Finished Parts
Step 10: Solved Puzzle
Can you figure out how it went together?
Step 11: Solution
Solution:
- Start with Block 1 (green piece)
- Slide Block 2 (purple piece) through slot
- Slide Block 3 (cyan piece) down and through notch
- Slide Block 2 towards the center to complete the puzzle
Step 12: Pictures
I'm pretty happy with how it turned out. Thanks for viewing.
Pocket-Sized Contest
Trash to Treasure
Epilog Challenge 9
2 People Made This Project!
- Boogy4262 made it!
- JohnnyFiveAlive made it!
4 Comments
Question 3 years ago on Step 5
In the router step, I see that from one direction you use the router fence to cenenter the work, do you just free hand to a mark for the long direction or are you able to set up stops?
Answer 3 years ago
I just used freehand for the distances. Stops would be better if I was making more than one.
4 years ago on Step 5
Your picture also shows a rip blade being used to make cross cuts. Using a crosscut or combination blade will provide much better results. As you mentioned, it would be better to use a stop block on your miter gauge or at the very least, clamp a block onto the rip fence so that the block is 6 inches from the blade and set the block well ahead of the blade.
4 years ago
PRettty lit
