Wooden Outdoor Folding Chair
Intro: Wooden Outdoor Folding Chair
Here is a surprisingly comfortable chair that, depending on your method of finish, can be completed rather quickly with basic hand tools. Depending on your skill level and access to power tools, several of these chairs are capable of being "mass produced" as the measurements are straightforward, so jigs are well worth the effort.
STEP 1: Materials / Tools List
The wood is your choice - I would stay away from pressure treated wood as the increased moisture content during the process, typically causes fairly erratic warping and twisting in stock this size as the wood dries. This could keep the chair from properly folding and / or supporting the weight. While we are on the subject, premium Yellow Pine (no knots or obvious defects) 1x2 lumber produced a chair capable of supporting more than 350 pounds.
Each chair will require:
Qty Desc
5 1 x 2 x 96 inch Lumber Stock
2 3/16 x 36 inch All-thread
8 Washers / Nuts
Tools
Hand saw (preferably with a miter box, or miter saw)
Drill (again, right angles are important here, so a drill press is useful)
Method of Finish (optional)
Wrenches (Sorta optional, mostly everything needs to be hand tightened)
Hacksaw or other method of cutting the All-Thread
Qty Desc
8 Washers / Nuts
Tools
STEP 2: Cut List / Drill List
For the purpose of clarity, there are 6 specific pieces that will need to be fashioned, varying quantities of each.
Support Brackets - Qty 9
Ends Mitered at approx. 45 degree angle, offset (like the rails or stiles of a picture frame /----\ )
Long length 8 3/4 inches
Sort length 6 inches
Hole spacing 5 1/2 inches centered
Seat Rails - Qty 6
15 inches long
1/4" hole 3 inches from rear
1/4" hole 1 inch from the front
Seat Leg - Qty 2
36 inches long
1/4" hole 12 inches from the front
Back; Short - Qty 2
22 1/2" long
1/4" hole 3 inches from bottom
1/4" hole 1 inch from the top
Back; Long - Qty 4
24 inches long
1/4" hole 4 1/2" inches from bottom
Back Leg - Qty 2
36 inches long
1/4" hole 16 1/2 inches from rear
All-Thread - Qty 2
16 inches long - to be trimmed at the end
All-Thread - Qty 2
12 inches - to be trimmed at the end
Seat Rails - Qty 6
15 inches long
Seat Leg - Qty 2
36 inches long
Back; Short - Qty 2
22 1/2" long
Back; Long - Qty 4
24 inches long
Back Leg - Qty 2
36 inches long
All-Thread - Qty 2
All-Thread - Qty 2
STEP 3: Assembly
Once your pieces cut, drilled, sanded and finished to your liking, it's time to assemble
I apologize for not having the foresight to take pictures during this step. The two short pieces of all thread are for the top of the back and front of the seat. The two long ones connect the brackets and the back of the seat to the bottom of the back. Each layer is as described b
The order, starting from either side is:
Bracket
Back Leg / Seat
Bracket
Back Short / Seat Leg
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Bracket
Back Leg / Seat
Bracket
Keep the long All-thread rods loose until the front and top are tight - then tighten them down. You should be finished once the all thread is trimmed and filed to eliminate any burrs. Some additional Chamfering may improve comfort, but even without this step the chair is remarkably comfy by the fire! Enjoy!
Bracket
Back Leg / Seat
Bracket
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Back Long / Seat
Bracket
Bracket
Back Leg / Seat
Bracket
5 Comments
rimar2000 10 years ago
Gregmink 10 years ago
FN64 10 years ago
I built a jig for drilling as there are many repeated measurements.
I also use a saw sled for the repeated cuts..
FN64 10 years ago
Thanx again for the ible..FN
