Personalized Wooden Key Organizer
25,390
845
23
Introduction: Personalized Wooden Key Organizer
This is a key organizer I had made for myself. I was tired of being poked in the legs by my keys everyday and wanted to eliminate the jingle every time I went to open my house door. This project was made with scrap materials I had laying around. (Note: I didn't think to take pics as I was going but I will try to explain the process.)
Step 1: Step 1
Found piece of wood that measured 7/8" in width which was sufficient to house the keys. From this piece I cut two pieces at a length of 3 1/8".
Step 2: Step 2
Dug through a pile of miscellaneous screws and nuts to find a matching set of 2. After this the two wood pieces were placed together and holes were drilled 1/4" from each end.
Step 3: Step 3
A place to grab the keys was sanded out using a Dremel. And the holes on one piece of the wood(which will end up being the backside) were drilled half way through to allow me to countersink the nuts.
Step 4: Step 4
The wood was then engraved with the initials, sanded and polyurethaned and left to dry.
Step 5: Step 5
In the meantime I cut a piece of sheet metal (1/2" x 2 1/2) for the pocket clip. The piece was cleaned and polished using varies grits of sandpaper until a desired finish was accomplished. Edges were then rounded and shaped(dremel). Then an offset hole was drilled so that it would clear the "key pullout slot". Finally it was bent into the proper shape using a pair of pliers.
Step 6: Assembly
The screws were fed through the holes and then the keys started being placed. Washer,then key, then washer, then key and so on. Everything was then tightened to a point where the keys were firm but could still be pulled out with ease. (The screws I found were too long so I ended up grinding off the excess after it was tight.)
Step 7: Conclusion
This is the first instructable Ive made so I hope your were able to follow it through til the end. Hope you enjoyed viewing as much I enjoyed creating and sharing. Thanks for stopping by! PS: If you like this project please vote for it in the wood contest, it would be awesome to win some new tools!
Wood Contest
Wood Contest
Homemade Gifts Contest
Be the First to Share
    • Halloween Contest
      Halloween Contest
    • Plywood Contest
      Plywood Contest
    • Teach With Tinkercad Contest
    23 Comments
    mduncan6
    mduncan6
    7 years ago on Introduction
    Very clever. I'm a fan of those tactical key keepers made of leather or cordura (that wrap around from three sides and secure with a button), but this is a beautiful design - I could definitely imagine making your own EDC with other attachments or hidden compartments with the wood. Well done!
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thank you sir. Ive been tinkering with a few other designs as well. Hidden compartments is a cool idea! Ill see what i can come up with. Thanks for stopping by
    joelwashing
    joelwashing
    7 years ago on Step 7
    So well done! I love your design and the belt clip. Cheers!
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thanks a ton; glad you enjoyed this project of mine! Salute!
    mazmoiz
    mazmoiz
    Very cool !! Liked this project. Voted your instructable....
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thank you very much!
    FCPglasmyre
    FCPglasmyre
    Hi Dennis! I'm a junior editor at Scroll Saw Woodworking & Crafts, and we love your project! Would you be willing to submit it to the magazine as an article? Email me at glasmyre [at] foxchapelpublishing.com. Thanks! Carly
    rdaly4
    rdaly4
    7 years ago
    i enjoyed reading your instructable. you obviously put some serious contemplation into the project.
    KetalonG
    KetalonG
    Dennis mate, that's absolutely beautiful! You've even applied polyurethane and made it look like a pro art collectible.
    We make a similar gadget in hard polymer (next batch coming soon), would love your feedback! : ketalon.com/products/Keyn
    Keep up the cool work!
    - Renton from Ketalon.com
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thanks! Checked your product and the only feedback i have is that you should try offer it in different colors. Good luck on your endevour
    KetalonG
    KetalonG
    Reply 7 years ago
    And we will thanks!
    zwilmes
    zwilmes
    For a more slim profile you could countersink the screw holes slightly and then add a washer in the holes if needed for strength. This would make your screw head sit below the wood surface.
    Great instructable, I'll definitely be making one of these!
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thanks buddy...when you finish, post a pic id like to check it out
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thanks! Its amazing what can be done with just some old material and an idea
    DennisPelle
    DennisPelle
    Reply 7 years ago
    Thank you sir
    DennisPelle
    DennisPelle
    Similar, but this was free; and fun to make :)
