Wooden Work Deck
Intro: Wooden Work Deck
Having used cardboard to protect my desk and bench while working on instructable projects for the last few months, I thought making a small work deck from plywood was an idea overdue.
As I don't have a large selection of woodworking tools, I improvised a little by using a mitre saw to cut corners and a barstard file to smooth them.
STEP 1: Corner Up
Using a piece of 8mm, by 300mm by 400mm plywood which I had on hand. I marked out some rounded corners.
STEP 2: Cutting the Corners Straight
As I only have a mitre saw, I used this to cut the corners with a number of radius cuts.
STEP 3: Smooth
The corners were them smoothed with a bastard file.
STEP 4: Cutting Edge
Using a 40mm by 8mm board, which I had on hand, an edge was made by cutting two 220mm lengths.
STEP 5: Edging
The two lengths were glued on top of each other with pva glue to make a 16mm thick board of 220mm length.
This was then glued onto the plywood to make an edge. I had been thinking of screwing it on but just the glue worked fine.
