Introduction: Wooow!!! 3V DC MOTOR Forced at 4000V | Awesome Idea New DIY
Hi!
In this instructable you will how to make the high voltage DC output circuit at home with the help of 2 CFL inverter circuits and a laptop charger. The project is very dangerous coz it not only contains high voltage but also high current that can easily electrocute any living being.
I have operated a few DC Motors to see how they adjust around the high voltage supply and they perform really good.You should watch the operations of the motors at such a high voltage.
The technique is different than the normal plasma discharge voltages where more importance is given to arc length and voltage but here , i have given equal importance to the current.
Full Video Link : https://www.youtube.com/watch?v=JY6MGQkk8dM
Youtube Channel Link : https://goo.gl/gIb28V
Step 1: Requirements:
Requirements:
1- 12 volts to 220 volts CFL inverter circuit.
2- one laptop charger
3- rubber gloves
4- eye protection
5- power supply
6- crocodile clips
7- some wires
8- DC Motors
Step 2: Circuit Connections:
Take the 2 CFL inverter circuits and connect their DC input side in parallel and the AC output sides in series.
Now take a DC Motor as shown in the images and connect the high voltage output wires from the CFL inverter circuits to the motor terminals.
Now get a DC supply ranging from 12 volts to 20 volts DC. I used a 19 volts laptop charger. Make sure that you are not in contact with the circuit before proceeding to the next step.
Step 3: Testing:
Now connect the terminals of the laptop charger to the input terminals of the CFL inverter circuits.
You should see that the motor starts and keeps on accelerating to attain the maximum possible speed.
You motors won't get damaged if operated for a small period of time coz the current is only up-to 0.15A.
This high speed motor operating trick can also be used to operate drone motors.
Thankyou!!!!!
