Wordy Art: a Picture Worth 1000(+) Words
Intro: Wordy Art: a Picture Worth 1000(+) Words
This will show you how to make a picture worth more than a thousand words (literally). I've always been a fan of large scale art that takes a collection of small objects to make a large image, and so in high school I created this self portrait using the text of Thoreau's "Walden".
STEP 1: Picture
First, you're going to need a picture. Anything will work, but those with high contrast work the best. In highschool, I took pictures of my face with a light bulb right next to it to increase the amount of shadow.
I'm sick of my face, so lets use my roommate's.
STEP 2: Tweeking Your Photo
Open your photo in Adobe Photoshop or a similar program. I have limited experience in some of the similar free programs, so for this instructable we'll be sticking to Photoshop.
First, Grayscale the image. Hint: play around with the contrast/brightness of your image, or Equalize the image to make the shadows and relief more pronounced.
After you are satisfied with the Grayscale, Posterize the image. REMEMBER HOW MANY LAYERS YOU DECIDE UPON. The less layers you posterize with, the easier the following steps will be. The more layers you use, the more impressive the effect will be. For this case, I chose 4 layers.
Play with your image until is just as your heart desires.
STEP 3: Text
Now select the text you want your image to consist of. Keep in mind how large you want your image to be. As we format the text, the size of the entire selection will grow.
Open your text in Microsoft Word or a similar program. Remove all paragraphing so the text is uniform. I used a long exerpt (a chapter from Thoreau's "Walden"), but for this example I'll use something shorter, but of the same philosophical and poetic caliber, the lyrics to the Fresh Prince of Bel-Air theme song, repeated.
STEP 4: Format Text
Once you have your text, you need to make your page as large as you want your image to be. The original in the Intro is about 22" by 22". I used my high school's architecture department's printer to make a picture this big, but if your closest school doesn't have a large printer, I'm sure kinko's would be able to help.
Choose a page size and text size that will give evidence to the large image while allowing the text to be readable.
To change page size in word, use Paper Size under Page Setup in the File menu. In this case, I choose 12" by 12" and size 8 Times New Roman font.
STEP 5: Inserting Picture
As a reminder, try to make the text just a few lines shorter than the entire size of the page (or the page just a bit bigger than the text). It may look unbalanced, but you can play with the margins at the end to make it look better.
Insert your posterized picture into your word file. Format the picture to be behind the text and to size of the margins (so directly behind the text).
You may have to format your page/font size a bit to make sure the image is large enough without distorting it.
STEP 6: Change Text
Eventually, we are going to change the color of each letter, but since that would take forever to do individually, we'll label those letters we want to change so they are easier to identify later, in groups.
So pick a few text formats you can create quickly; for instance, those letters above the darkest layer, I'll change to bold (Ctrl B), those below the lighter layer I'll underline (Ctrl U), those under the even lighter layer will be in italics (Ctrl I). Finally, the lightest layer I won't do anything to ("regular").
Now go line by line highlighting and changing the text appropriately. Yes, I know, its tedious.
You'll note that the smaller the text the more detail you will be able to see. If you want, you can change the spacing between the letters and lines to bring the text closer together without making the text it is too small to read.
STEP 7: Adding Color (shading)
No one wants a picture made of bold, italicized, and underlined words. We need some shading.
Once your entire text matches the underlying image in bold/italics/underline/whathaveyou, you can remove the picture from beneath the text.
Using the Find function (Ctrl F) we are going to replace all the altered text. Under the "Replace" tab, click the "More" button to expand the window. With the curser in the "Find" field, click the "Format" button and choose "Font". When the Font box pops up, choose your font and what format you want to change (bold/italics/whatever). Hit ok.
With the curser in the "Replace" field, do the same thing, but choose the font you want to change it too: i.e. if I'm finding all times new roman bold, I'm going to change it to times new roman regular, black. If I'm finding the italics, I'm replacing with regular, light gray, and so on.
Hit replace all.
Do this for each format. Try your best to have the shade of gray you choose match that in your posterized picture. (you may want to keep your picture underneath during this step, so you can see how colors line up.)
However: when you do your lightest color, you can't change the font to white, as then you can't read it. With 4 layers, I made the darkest black, the next darkest 75% gray, the next 50%, and the lightest (supposedly white) 25%.
Also, start adding shading with your "regular" font, if you have one. Otherwise, as you change Bold to Regular, and then finally change all the "regulars", you'll change everything you've already done. Remember our friend Ctrl Z...
Hit replace all.
STEP 8: I'm a Cheater / Tips
You may have noticed in the last picture that the colored text did not take the shape it was supposed to. There are two reasons for this:
1. I cheated. In order to produce a concise instructable, I only formatted a small area of the picture instead of the entire image.
2. Changing from bold/italics/etc. and back again changes the letter spacing. This can drastically alter the picture. Here are some ways to get around this:
A. Leave them in. If you pick font formats that do not change the flow of the image, you can leave them in after changing the colors. So stick with bolds for the darkest areas, italics for the lighter ones, and stay away from underlines or strike-throughs that will leave scars in your picture.
B. Center all text Problems come when the change in format changes the spacing from left to right. Centering all text before beginning will make any spacing issues move outward, minimizing and damage.
C. Use different formats Bold drastically changes letter spacing, Italics less so. Experiment with other formats that you can use with the Ctrl pad to see what changes more or less.
D. ALL CAPS transitions between large and small font agitates the spacing problem. With all words in caps, or none in caps, less problems should occur. You can also use "all caps" as a format instead of Bold, for instance.
General Tips
Make the big image big, and the tiny text tiny. The larger the contrast in size, the more visual acuity and room for error you will have. In the one I've worked through here, the font was rather large for such a small image. Also, the bigger, the more impressive the effect.
Hang it in a prominent place! Remember to record how many double takes people make when they see it.
General Tips
23 Comments
Minmin4225 9 years ago
Heyentah 15 years ago
treehousee 15 years ago
Genetastic 15 years ago
Grey_Wolfe 16 years ago
Darkaef 16 years ago
netxtc 16 years ago
Toulouse 16 years ago
TheCheese9921 16 years ago
Falaco Soliton 16 years ago
AdamK 16 years ago
climber_geek 16 years ago
Chanmachine 16 years ago
brian2012 16 years ago
sandalian 16 years ago
beckinacea 16 years ago
ll.13 16 years ago
skeksil 16 years ago
http://homokaasu.org/rasterbator
I wonder if they would work together?
