Workaround for Outlook Mailbox Size Limit
Introduction: Workaround for Outlook Mailbox Size Limit
If your workplace uses Microsoft Outlook as the main method for communication, then your emails are located on a company Exchange server. There are limitations to this, and an especially annoying one for many is the size limit. There are only so many Mailboxes that can be stored on a given server, and your IT Department will have to enforce a limit on how much email data can be stored per Mailbox, so there's enough space for everyone.
Now where does that leave you? You would either have to decide which emails to delete as they enter your Mailbox, or wait until you hit your limit and can't receive any more- which means if you wanna keep getting those important emails from your boss and co-workers, you'll be spending a long time sorting through Inbox items and making some tough calls on which ones to delete. Yuck!
Fortunately, there's a nifty workaround that Microsoft had created just for this problem. It is called an 'Outlook Data File', or '.pst' filetype. A '.pst' is a file that can be stored on your computer's hard drive, not a server, and is just as easily accessible as your Mailbox in Outlook. Simply put, it's like a place to backup emails from your Mailbox to your local hard drive. There's a side-benefit too: when something like the network being down or a server gets fried, you can still access old emails stored on your '.pst', since it's on your hard drive; no Internet access required.
The process of creating a '.pst' is easy, but varies depending on your version of Outlook:
Step 1: Outlook 2003 or Outlook 2007
1. Open Microsoft Office Outlook and make sure you're able to access emails in your Inbox.
2. Select File > New > Outlook Data File...
3. Select 'Office Outlook Personal Folders File (.pst)' and hit' 'OK'.
4. A Windows Explorer Window will open. Choose a name and location on your hard drive to store your .pst file.
5. You are given the option to assign a name (doesn't have to be the same name as the file you just saved, but be careful to remember both) and create a password if necessary (not personally recommended). Once finished, hit 'OK'.
6. In the Left Pane of Outlook, a new Mailbox (your Outlook Data File) has been created. You can now move or drag emails from your Inbox to the Outlook Data File.
Step 2: Outlook 2010 or Outlook 2013
1. On the Home tab, under New group, click New Items, hover over More Items, and then select Outlook Data File.
2. In the File Name box, type a name for your new Outlook Data File, then hit 'OK'.
3. With Password you may create a password (personally not recommended.)
4. Your Outlook Data File is accessible in the Navigation Pane (Left).
Step 3: Good to Go!
Your Outlook Data File has very similar functionality to your Mailbox. You'll learn to love the '.pst' as your method of storing important emails without stress or worries. More information on .psts in Outlook 2003 and 2010 can be found here, and info on the Outlook product here.
Be the First to Share
    • 3D Printed Student Design Challenge
    • Hide It Challenge
      Hide It Challenge
    • Cookie Speed Challenge
    13 Comments
    RichardW38
    RichardW38
    5 years ago
    Perfect solution is here Outlook PST Repair Software is a most successful application that performs efficiently most of its time.It uses advanced technologies to scan the corrupt Outlook personal folders (.pst) files and recover your mail messages, folders, posts, calendars, appointments, meeting requests, contacts, distribution lists, tasks, task requests, journals, notes, etc.See more info download now:-
    http://www.recoverfilesdata.com/outlook-pst-repair.html
    RexT2
    RexT2
    6 years ago
    I have been using this outlook pst recovery tool that help me to repair and recover corrupted and damaged pst files. And I would recommend all other Outlook users to use the same tool as it is very easy to use and it effectively recovers all the objects of Outlook PST file. Read More OR Download:-
    http://www.undeletepcfiles.com/outlook-email-pst-recovery.html
    AlbertWheeler
    AlbertWheeler
    Reply 6 years ago
    Increased size of Outlook mailbox is most critical situation. Due to oversized PST file there are chances user Outlook PST file got corrupt. Recently my Outlook PST file size exceeds above 40GB and got corrupt. I discussed my issue with Outlook email recovery experts. On suggestions I opt for Stellar Phoenix Outlook PST Repair software- Tech to repair corrupt PST file. Using tech version I can split and compact my large sized PST file too. This would be of additional benefit for large sized Outlook PST file users. After using the software I would suggest recommended PST Repair software for every user who wishes to repair corrupt PST file. For more info please visit the URL:
    http://download.cnet.com/Stellar-Phoenix-Outlook-PST-Repair-Technical/3000-2369_4-76161041.html
    AlbertWheeler
    AlbertWheeler
    Reply 6 years ago
    KennyC8
    KennyC8
    6 years ago on Introduction
    If you are in trouble due to Outlook mailbox corruption and lost almost all important data. In such condition there is a perfect and suitable solution available in the market which is well know as Outlook PST Repair software to smoothly repair and recover badly damaged or deleted emails and other PST files without any problem.
    For more information visit here :-
    http://www.filesrepairtool.com/outlook-pst-repair.html
