Workshop Chair With Air Compressor From Scrap
Intro: Workshop Chair With Air Compressor From Scrap
Hello everyone, in this project I wanna show you how to make Workshop Chair with Air Compressor inside. All parts to make this project I found in scrap. I made video and step by step instruction how to make it.
Materials :
- 2 old car's rims
- 3 small wheels
- steel profile
- screws amd nuts
- air compressor
- piece of wood
- clear varnish
Tools :
- welder machine
- hamer
- pencil
- belt sander
- table saw (or bandsaw)
- grinder machine
- pliers
- brush
If you have any questions, please leave comment below.
I hope you enjoy and thanks for watching :)
STEP 1: Make Tamplate of Rim's Edge
Make template of rim's edge, it is very helpful with cutting steel profile.
STEP 2: Cut and Weld Legs
I prepered 3 legs to my chair, angle between them is 120 degree. Draw path using templates and cut a shape. When your legs are well matched to rim, just weld them.
STEP 3: Wheels
Now prepare wheels to welding. I had to improve them a little bit. When wheels are ready, just weld them to legs.
STEP 4: Time for Air Compressor
I used compressor from old fridge. To connect compressor with rim use bolts with nuts. When everything is in place, weld second rim on top.
STEP 5: Make a Little Hook
Make a little hook and weld it to the chair. Hook will help organize cables.
STEP 6: Cut Circle From Wood
Now take some piece of wood to make a seat. Clean surface (I used belt sander) and draw a circle using beam compass. Cut circle and improve the edges. After that screw seat to chair.
STEP 7: Paint and Done :)
When chair is assembled you can start paint . I painted only wooden circle (clear varnish). I not painted the other parts, because I like rusty style.
Now your chair is finished ready to use :)
I hope you enjoy.
4 Comments
HariKarier11 7 years ago
Thomas Workshop 7 years ago
Under seat I put a rubber pipe conected to compressor. So when I must oil compressor I just connect syringe with oil to rubber pipe and injects :). I rarely use compressor and oil 2 times per year is enough.
KennethM42 7 years ago
katmat30 7 years ago
I really like your idea! You can find all those parts so inexpensively and make it fancy or rustic. Next time I go to the scrap yard I am going to look for some rims!
