World's Best Dark / Light Sensor! (No NPN, PNP or IC!!)
19,335
23
20
Introduction: World's Best Dark / Light Sensor! (No NPN, PNP or IC!!)
About: "May the good belong to all the people in the world. May the rulers go by the path of justice. May the best of men and their source always prove to be a blessing. May all the world rejoice in happiness. M…
World's best Dark / Light Sensor!
NO Integrated Chips!!
No NPN, PNP transistors !!
Only an LDR and a Resistor !!
Step 1: Video Link
Step 2: Steps
1.Just connect any leg of LDR to any leg of LED. You can increase the light sensitivity by connecting two or more LDRs "in parallel" (like i have).
2.a) For dark detecting sensor (lights up when dark):
Choose a resistor, from 10 kilo ohms to 150 kilo ohms, in decreasing order of sensitivity to light.
Connect the resistor to the positive leg of the LED and the DC battery.
Any voltage DC battery will do.
2.b) For light detecting sensor:
Connect the resistor to the negative of the LED and the DC battery.
Done !!
http://www.youtube.com/watch?v=dh01O22A0Xg&feature=youtu.be
Step 3: Advantages
1. Simple sensor circuit - actually no circuit at all!
2. No soldering required - relief for those allergic to it ! (like me!)
3. I have just pressed the circuit between a 9 volt battery and its cap. Even the battery cap wires were not used!!
Genius! (Idea, of course!) ;-)
Rate and vote, if you liked it!
Step 4: Dark Sensor Circuit
Here is a simple schematic circuit diagram of the dark detecting sensor circuit for led...
Step 5: My Other, LED Plug Light
SciStarter Citizen Science Contest
Instructables Design Competition
Make It Glow
Make It Glow
Be the First to Share
    • Anything Goes Contest 2021
    • Raspberry Pi Contest
    • Jewelry Challenge
      Jewelry Challenge
    20 Comments
    JaidulI
    JaidulI
    5 years ago
    Hello Everyone,
    I am trying to make a circuit by using LDR, 548 Transistor, 5V battery, LED. I want that LED should turn on when the LDR sense dark but in my system it's reverse. Could anyone please tell me why it's happening. I am not using any register. Should I use on it. If I should, please tell me why I should use register and how may I measure that what ohms register will be used.
    Thanks
    RishanR
    RishanR
    Reply 4 years ago
    Congrats ,you have just made a
    light activated switch.
    pandyaketan
    pandyaketan
    Reply 5 years ago
    reverse the pnp connections and check... else search for "dark detector circuit" on instructables as well as google... hope it helps...
    ojasvinew
    ojasvinew
    4 years ago
    hi everyone i am saying about is it really works?
    faziefazie
    faziefazie
    8 years ago on Introduction
    Awesome tutorial, I try to make a dark sensor but I don't have IC or transistor, I just have LDR and LED, so I found your tutorial and I made a dark sensor for my room because I usually forget to turn on the light when my room getting dark in the afternoon. So I created it such a warning box for reminder me to turn on the light.
    Thank you for the tutorial. Greeting from Indonesia.
    AndrewP14
    AndrewP14
    Reply 6 years ago on Introduction
    Hi please help me with this? - im a total newbie trying to learn how to dabble in the "dark arts" :-) Cant get my circuit to work and dont know whats wrong. Here are the various parts i have used.
    Transistors
    Bc547; Tip127; 2n3904 - could this be the problem? The tip127 is the only PNP Transistor i can see according to the data sheet...
    3x Different types of Leds. Red:1.2vF White :3.2vF,
    3x differnet types of light detectors
    - Photo Transistor 940nm
    -Photo Sensor 940nm
    - LDR
    Battery i am using is a 1.0ah 4.1v battery (4.1v is actual tested voltage)
    2x POTS, 1x 1k, and another 10k pot.
    Doing above on a breadboard
    The problem is, The both LEDS stay on when connected, they just get brighter with more light, it seems my circuit is more of a light detector that switches LEDS on when it detects light rather than the opposite way around?
    Ive tried switching the transistors, switching the leds, switching the POTS, and some other resistors i had (not sure of spec right now) but still cant get it right?
    what other info can i add for you to assist?
    Thanks, Andrew.
    pandyaketan
    pandyaketan
    Probably, interchanging the Emitter and Collector connections of your pnp should do it.
    Search for "Dark Detector" (Solar) circuit, here or on google and compare your diagram....
    hope it helps, since you have not provided a link to your circuit...
    AndrewP14
    AndrewP14
    Hi Pandyaketan - Thank you so much for your response - i was going nuts trying to figure it out after over 10-12 hours of tampering, changing etc. Turns out it was the resistance value leading to the (Base) of the transisor - the resistance was not high enough, i used a 300k resistor from (+) to Base on one side, Photo-transistor on the other side of Base (transistor in the middle of the board -using breadboard).
    See below image - i used a different schematic.
    Again, Thank you for your assistance.
    pandyaketan
    pandyaketan
    Wow! Even better than the real thing! ;-)
    May rain come in time and plentifulness be on Earth.
    May this world be free from suffering and the noble ones be free from fears"
    ---- Vedic blessing
    AndrewP14
    AndrewP14
    Transistors
    -Photo Sensor 940nm
    - LDR
    Thanks, Andrew.
    ClownW
    ClownW
    7 years ago on Introduction
    i dont get how the ldrs even effect the circuit the are beyond the led
    please help me understand
    pandyaketan
    pandyaketan
    LDRs behave as light switch...
    they decrease resistance, when light falls on them and complete the circuit....
    try it....
    ClownW
    ClownW
    so just wire two ldr's to each leg of a led? thats it? well and power source
    pandyaketan
    pandyaketan
    and a resistor 10 KOhm (upto 150 kilo ohm), to the positive, as per circuit in the I'ble....
    cemcem1974
    cemcem1974
    This is not efficent way of using energy. What you do is simply shortcircuiting the led via the ldr. When the ldr gets light it simply drops the resistance. There would be no difference therefore whether it is night or day it will consume exactly the same energy from the battery.
    pandyaketan
    pandyaketan
    1. Its not about night or day, its about light and dark, regardless of whether its day or not.
    2. LDR controls the battery energy by offering resistance, maybe you should read more.... else it would not have been used in "any circuit", not just this!
    3. About 'efficiency' - if our civilization has resorted to efficiency and transparency, everything would have been free and everyone would have been happy and blissful. Most useful projects do not reach us, even though we fund them.
    ---- Vedic blessing
    Bill WW
    Bill WW
    9 years ago on Introduction
    NPN, PNP, LDR?
    Maybe you could provide a definition of these TLR's (Three Letter Aconyms) for the non-electronically inclined.
    I've got IC figured out.
    Thanks. Nice work, by the way.
    pandyaketan
    pandyaketan
    NPN and PNP are types of transistors.... wiki might help, here it is:
    http://en.wikipedia.org/wiki/Bipolar_junction_transistor
    LDR is Light Dependant Resistor, again search wiki ! ;-)
    And thank you!
    reg
    ketan
    ---- Vedic blessing
    pandyaketan
    pandyaketan
    Typical Cadmium Sulphide one...
    http://en.wikipedia.org/wiki/Photoresistor
    reg
    ketan
