X-Wing Starfighter
Intro: X-Wing Starfighter
I made this X-Wing out of Maple burl with a few Walnut inlays. It's 9" long, it has a 10" wing span, and is 5" tall.
STEP 1: Rough Turning the X-Wing Body
I'm starting out with a 10" X 3 1/2" X 3 1/2" piece of Maple. Turn this piece down to the basic shape, roughly a 9" X 2 1/2" cylinder.
STEP 2: Laying Out the Ship's Hull
I used the indexer on the lathe to lay out the basic shape. I put a center line down both sides, and then went up 1/2" on each side. Do the same for the bottom, 1/2" down from the center line. The windshield is 6" from the nose, and 1 1/2" X 1/2"
STEP 3: Carving the Ship's Hull
I tapered the nose cone, and used a woodworking chisel to take off most of the wood. After getting the shape defined, I sanded it with a DA with 100 grit sandpaper.
STEP 4: Inlaying the Windshield and Wing Windows
I cut out three pieces of Walnut to inlay for the windows. The windshield is 1 1/2" X 1/2" The two side windows are 1 1/4" X 1/2" tapered to a point. I traced around all three pieces, and carved them out with a chisel. Glue them in flush to the hull. After the glue dries, sand till smooth.
STEP 5: Cutting the Mortise for the Wings.
I used a high speed cutting wheel to cut the 4 mortise for the wings. 1 3/4" X 1/8" each
STEP 6: Making the Wings
I cut the wings out on the band saw 4" X 2" X 1/4" taper the wings down to 1" at the tips. I used double sided tape to hold all four wings together, while I sanded them. I cut a tenon on the band saw on the 2" side of the wing 1 3/4" X 1/8". Drill a 1/8" hole in the 1" side "tip" of each wing. A drill press works best for this.
STEP 7: Back of the Thrusters
You'll need four of these 2" X 1/2"
Put a small tenon on one end 1/4" X 1/4" this will be used to glue the front and rear thrusters together.
STEP 8: Front of the Thrusters
You'll need four of these 1 1/2" X 1"
Use a 3/4" forester bit to drill in 1/2" on the front end. Put a 1/2" collar on the front end, and taper down 1/8".
STEP 9: Back of the Cannons
You'll need four of these 1 1/2" X 1/2"
Drill a 1/8" hole in the front of each one. I put a small tenon on the back side of these as well for detail 1/4"X 1/4".
STEP 10: R2D2
I just turned R2's head to mount behind the cockpit 1" X 3/4" My wife painted it after I sanded him.
STEP 11: Front of the Cannons
You'll need four of these 5 1/2" X 3/8"
Tapered down to 1/4" About half way down the cannon. At the point it's 1/8"
STEP 12: Drill a Off-center Hole in the Thruster
There are two pieces to each thruster.
Dill a slightly off-center 1/4" hole about 1/4" deep, in each of the four front pieces on the back side.
STEP 13: Drill a Hole in the Rear Pieces of the Cannon
There are four rear cannon pieces.
Drill a 1/8" hole 1/4" deep in the center of each of the rear cannon pieces.
These holes are for the 1/8" dowels that will be used to mount the cannons to the tips of the wings.
STEP 14: Glue the Thrusters Together
Glue the front and rear thrusters together.
Put a small bit of glue in the 1/4" hole, and glue the rear tenon in.
STEP 15: Glue the Cannons Together
Glue the front and rear cannon parts together.
Place a small bit of glue in the 1/8" hole, and glue the front tenon in.
STEP 16: Drill a 1/8" Hole in the Thrusters
After the glue dries on the trusters, Drill a 1/8" hole in the center of each of the four thrusters about 1/4" deep.
STEP 17: Glue on the Cannons
Glue a 1/2" X 1/8" dowel in the hole you drilled in the back piece of each cannon.
Glue it to the tip of the wings in the 1/8" hole you drilled.
STEP 18: Gluing the Thrusters on
Glue a 1/2" X 1/8" dowel in the front of the thrusters. Place on the wing, and mark the dowel position on the hull. drill a 1/8" hole in the hull to mount the thruster. Place a small bet of glue on the dowel, and glue in.
STEP 19: Apply the Finish
I used Howard beeswax and Orange oil, but you can use any finish you like.
STEP 20: I Hope You Enjoy This Project
The final step is to glue in R2D2 I put a bit of glue on the bottom, and set him in.
33 Comments
DanL63 7 years ago
Jenna♥ 8 years ago
this is amazing! great details thank you for sharing
Carl Jacobson 8 years ago
Thank you very much Jenna!
Octopus Prime - Craft Maker Infinity 8 years ago
WOW. I have now followed your Instructables page sir, and when I get my Youtube channel squared away I'll follow your channel as well. Keep up the good work!
Thank you very much!
No problem! You and your wife are amazing at what you do! Keep up the good work sir! Have a great year!
patricksworkshop 8 years ago
awesome work thanks
Thank you Patrick!
jedii72 8 years ago
The wood working force is strong with this one. Very cool!
:) Thank you!!
alexeicharkham 8 years ago
Just totally incredible. I take off my wig to you, sir!
lol Thank you Alex!
David Catriel 8 years ago
Nicely done, and glad to see you're on instructables as well. Your youtube channel is very interesting!
Thank you so much David!
Jedi_zombie85 8 years ago
AMAZING WORK, TRULY AN ART FORM
Thank you very much!!
iluvasianchx 8 years ago
f'ing brilliant
:) Thank you!!
kylegilbert 8 years ago
Thank you very much Kyle!
