XY-Plotter
Intro: XY-Plotter
Perhaps you have never been gifted at drawing, or you don’t have the time to do it yourself, so why not let a simple x-y plotter draw for you. This simple two axis device can accurately moves a pen to draw out anything.
The Device:
The x-y plotter has a two axis control and a special mechanism to raise and lower the pen. The plotter has a hole in its base where the pen goes through. It was designed to print on both paper or any surface such as a wall; simply place the plotter against the surface and the pen will draw away through the hole. Each axis is powered using a single stepper motor and belt. Pen control is achieved using a servo. All electronics are controlled by an Arduino and powered by a 12 volt wall adaptor.
A Demo Video
The Team:
This project was completed by Tommaso Buvoli, Kristina Callaghan, Bruce Deakyne, and Phillip Dunlap for CU Boulder Things that Think Spring 2011.
STEP 1: Materials
- A Laser Cutter capable of cutting pieces up to 18” long.
- Band Saw
- Drill Press
- Screwdriver
Raw Materials:
- Several sheets of 1/4 inch thick acrylic (One side must be at least 18”).
- A small sheet of 1/8 basswood
- Several 1/4 inch dowels (metal or wood - at least 18”)
- 14 small long bolts and nuts
- 28 washers
Electronics
- 2 Gear & Belt combo sets: http://www.goldmine-elec-products.com/prodinfo.asp?number=G15973
- 2 high torque stepper motors: http://www.goldmine-elec-products.com/prodinfo.asp?number=G18202
- 2 stepper motor drivers (ULN2003A)
- 1 breadboard
- 1 2.5v, high current supply
- 1 5v supply (for arduino, USB cable acceptable)
- 1 EasyDriver Stepper Motor Driver (http://www.sparkfun.com/products/10267)
STEP 2: Printing & Assembling the Base
When assembled, the base look like a square with the center cut out. Attach the four sides using the 4 screw holes on each piece. Bolts should slide easily though the base pieces and tension is achieved by tightening bolts on the nuts which should be loosely wedged into each strut as shown in following the picture.
Two wooden dowels can be inserted through the struts on each side of the base.
STEP 3: Printing & Assembling the X-axis
Once the base is constructed two dowels can be inserted through the holes in the two light grey sides, as shown in the second diagram.
STEP 4: Building the Y-axis Housing
STEP 5: Building the Marker Holder
STEP 6: Belts and Gearing
To mount the x-axis motor, it is best to move the strut closest to the gear back. After affixing the small gear to the motor shaft with gorilla glue or epoxy, align the motor gear with the belt gear. The stepper should be upside down as in the picture below. Adjust the height so that the two gears are flush. Mark this on the strut. Use epoxy or gorilla glue to fix one side of the strut to the motor - preferably the side that allows the wires to face in the y-axis direction (as seen in the photo below).
Once the motor is attached, position the strut such that the two gears are aligned. Hold the strut in place, move the belt; if your gear is off center, you may need to adjust the motor position. Once you're found the "sweet spot" so the gears mesh evenly, mark where the two new screw holes for the strut will do. Drill and mount the strut. We also found that adding two small acrylic "guides" to the bottom of the y-axis allowed the belts to move the y-axis better.
The exact process can be replicated for the y-axis. Note you may need to counter-balance the y-axis motor with a weight on the other side.
STEP 7: Electronics
The electronics are fairly straightforward.
Place the two ULN2003A motor drivers in a breadboard.
The digital output can come from any of the PWM pins on the Arduino. These can be specified in the software on the next step.
Each motor will require 4 pins on the arduino (call them pins A-D, depending on which PWM pins you chose), one for each stepper motor coil/phase.
Attach Pins A-D from the arduino to pins 1-4 on the ULN2003.
Ground the driver's pin 8 and attach the 2.5V (high current supply) to pin 9.
Attach the colored stepper wires to the driver chip in the following order:
Pin 16: Orange
Pin 15: Black
Pin 14: Red
Pin 13: Yellow
Pin 9: White
The Stepper Motor datasheet and ULN2003 pinout are attached.
To generate the video, motors were attached to Arduino using the Easy Driver Stepper Motor Driver. The code used for moving the write head back and forth is provided below:
int stepPin = 2;
int dirPin = 3;
int LEDpin = 13;
int ii = 0;
void setup(){
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(13,OUTPUT);
digitalWrite(stepPin, HIGH);
digitalWrite(dirPin, HIGH);
void loop() {
for(ii = 0; ii<2000; ii++){
delay(5);
digitalWrite(LEDpin, LOW);
digitalWrite(stepPin, LOW);
delay(5);
digitalWrite(LEDpin, HIGH);
digitalWrite(dirPin, LOW);
delay(5);
delay(5);
STEP 8: Prospective Software
These can be found at reprap.org and replicat.org
STEP 9: Future Work
- Try to cut back substantially on platform, belt, motor, write head, etc. size to make a sleeker project.
- Invest in higher torque motors.
- Write a program to print an svg file in tiles.
25 Comments
abolfazl fakour 6 years ago
like
Waqar taj 6 years ago
savaliyacm 8 years ago
Thanks for info.
magno_23 10 years ago
danielffonsi 11 years ago
My contact email is danielffonsi@hotmail.com
grateful for the attention
valdenir 11 years ago
jduffy54 11 years ago
Remony 11 years ago
pankaj77 11 years ago
kalamgish 11 years ago
http://www.thingiverse.com/thing:17631
quasar93 11 years ago
Mojo_JoJo 12 years ago
kissubin 12 years ago
fgredauer 12 years ago
Fragmaster 12 years ago
jwoo2023 12 years ago
weldor 12 years ago
Your project is basically a very much improved version of the old pantograph and "tracers" used for drawing as well as router work. What you have built could easily (?) be modified to operate larger units in order to produce...
Like al of the others I commend you for your efforts. Truly a job well done!!
espdp2 12 years ago
Also perhaps substituting larger dowels - like 1/2" or greater - for less flex might help. Nice 'ible! 3/5 stars.
SHIFT! 12 years ago
