Head Option for Homemade Banjo
Intro: Head Option for Homemade Banjo
This is a way to make a head for a banjo on the cheap that I found whilst researching different ways to make homemade banjos. Originally I was using a cookie tin bottom cut out and place in with sheet metal screws. I found one guy that was using the p.e.t. plastic from soda bottles, but unfortunately, the world's soda producers seem to have quit selling those gigantic soda bottles, and the best I could get out of one would have been something like 8" tops. I did happen to have on hand some x-rays, which are mylar, just like banjo and drum heads, so I used those to experiment with. I also experimented with some HP paper that had a sort of mesh backing, that worked pretty well, but was again limited in size.
STEP 1: Materials
Old x-ray sheet, or large soda bottle with the flat surface cut out, or similar mylar or p.e.t. plastic you may have around.
Crochet ring, ring cut from a cookie tin bottom, or about any other ring shaped object that will fit into your banjo's "pot" (mine is an aluminum wok pan).
Epoxy glue- the 2 ton type worked better than 5 minute.
(optional clip lamp with warm bulb to speed curing time, and stretch the material)
Please note that this is just something I did for a junky homemade job. I'm not too sure how well it would work installed on an actual banjo. Of course I've seen some pretty weird stuff work, including a U.S. mail envelope, so...
STEP 2: Cut and Paste
Trace out your ring on the she sheet, and cut it out. Mix up your epoxy, and paint it onto the rim. Lay the rim on the mylar and let it do it's initial set so it can be handled. You'll want a good flat surface, and will probably want to weight down the ring while it cures.
STEP 3: Curing
Once the epoxy was initially set, I put it under a metal clip lamp with a warm bulb to speed the drying time, and stretch the mylar slowly. Take pains not to get the lamp too close, anything above about 150 f causes it to shrink very rapidly. I hovered it above the center with 3 or 4 inches clearance I think, and for this one it was sufficient to cure and stretch it in about 12 hours.
STEP 4: Mount It
For this one it just mounted into the pot with sheet metal screws. Probably using something like a metal ring will work much better when using it with an actual tension ring. On this, all you had to do was heat up the oven to 120 and stick it in there for a few seconds and it would re-tighten the tension- not the best way to make tension adjustments, but this is an early attempt.
6 Comments
Hazzard2theworld911 12 years ago
jelleAtProtospace 12 years ago
wobbler 13 years ago
underkill 13 years ago
craig3 14 years ago
underkill 14 years ago
