Introduction: XCP - Experimental Canard Platform
ENJOY, BUT BE SAFE !
Welcome to the XCP - eXperimental Canard Platform - This is a small simple catapult launched balsa wood glider which can be built in around one hour.
Tools.
- Cutting Mat or thick cardboard to work on; at least A4 in size.
- Pen/Pencil + Felt tips for decoration.
- Steel Rule
- Sharp Craft Knife
- Balsa Cement [Caution Irritant and Solvent] or a P.V.A. type wood glue.
- Some fine grade glass paper [Sand paper]
- 2 or 3 small square/rectangle blocks of wood or either square edged objects.
- Old lolly pop stick (optional)
Materials
- A thin piece of balsa measuring 80mm x 100mm x 2mm thick [3 inch x 4 inch x 1/16th of an inch] - make sure the grain is running along in the direction of the 100mm [4inch] measurement
- A coffee stirrer from McDonalds or other fast food outlet - 5mm x 140mm x 2mm thick.
- An elastic band, cut this so that it is an elastic strip about 150mm [6 inches].
- A small pea sized lump of blue tac or plasticine
Skills
- A little patience.
Once you have completed your glider you may wish to experiment with other materials - cardboard, polystyrene foam.
You may want to explore other arrangements of fins or add stabilisers that's ok this is what it is designed for a stable experiemtnal platform to explore flying.
Step 1: Step 1: Marking Out
Take your piece of balsa and lay it in front of you it so that you have the longest edges horizontally and the shorter edges vertically.
- Measure and mark 50mm [2 inches] from one short side so that you find the vertical middle of your piece.
- Draw a dotted line up your piece of balsa.
- Measure and mark 50mm [2 inches] from the bottom edge up each side of your balsa piece.
- Draw a dotted line across your balsa pice.
- Placing your steel rule on one corner mark a solid line through the centre of these two dotted lines out to the opposite edge of your balsa piece.
- Repeat Step 5 for the opposite corner to the opposite side
- On the top edge mark two points 25mm out from the centre on either side.
- Draw lines from these two points vertically downwards until they touch the lower diagonal lines drawn earlier.
- Using the Steel Rule and Craft Knife, carefully cut out the four pieces identified in the last image of this section.
- Using high grade/smooth glass paper sand all edges and flying surfaces until they are smooth.
After all surfaces are smooth you may wish to decorate your design at this stage; as it is easier to do so now rather than after the glider is assembled. Decorate the fore-plane first [the smaller of the two wing shaped pieces] you can then move to step 2 and then while the fore-plane is setting/drying you can decorate your other components.
Step 2: Step 2: Assembly
To assemble your XCP start with the fore-plane.
- Run a thin line of Balsa Cement or P.V.A glue down the centre of the fore-lane.
- Place the coffee stirrer [fuselage] so that 3-5mm sticks out the front and gently press it down onto the fore-plane.
- Support the sides of the fuselage to keep it vertical with two small wooden blocks or other square edged objects.
- Allow glue to dry/set - Balsa Cement takes approximately 10 minutes - P.V.A. wood glue - 20 minutes.
While the fore-plane is setting in place you may wish to continue with your decoration of the main-wing and tail-fin. Once the fore-plane has set and you have finished decorating your main-plane and tail-fin you can assemble these components.
- Run a thin line of Balsa Cement or P.V.A glue down the centre of the main-plane.
- Caution: Make sure you have turned the fuselage over so that the fore-plane is now on top of the fuselage.
- Place the fuselage so that 3-5mm sticks out the back and gently press it down onto the main-plane, place a small piece of scrap balsa underneath the nose of the fuselage to help keep it level and then use two blocks either side of the fuselage to keep it vertical.
- Wait at least 5 minutes.
- Run a small amount of Balsa Cement or P.V.A glue along one side and the bottom edge of the tail-fin.
- Place the tail fin near the rear of the main-wing in contact with the side of the fuselage.
- Allow glue to dry/set.
Once the main-wing and tail-fin are in place and the glue is set/dry you can fit the launch hook. This is a smaller triangle piece of balsa that is glued under the fore-plane in a similar fashion to the tail-fin.
Once the hook has been fitted it is a good idea to allow all glue to set/dry for a further 10/15 minutes.
While you are waiting you can cut your elastic band and tie a loop in one end. You can improve your launcher by attaching the other end to an old lolly pop stick if you wish.
Step 3: Step 3: Flying
SAFETY IS YOUR RESPONSIBILITY IF IN DOUBT DON'T FLY
Flying the XCP is a little like using a catapult or a bow and arrow.
Remember launching and flying aircraft is dangerous - make sure your flying area is clear of people, animals and anything breakable.
Finding the centre of gravity.
- Add a small piece of blue tac/plasticine to the nose of your glider.
- Using the edge of a ruler try an balance your glider so that there is between a 5-10 mm gap between the balance point and the main wing. See image.2 and 3.
- Either add or remove ballast (blue tac/plasticine) to or from the nose until the glider balances.
Trimming your glider.
- Gently holding the fuselage between the fore-plane and main-wing as though it was a dart
- With the nose ever so slightly ( 1 or 2 degrees ) high than the tail throw the glider gently using a long arm movement away from the body opening your fingers at the end of the throw to release the glider.
- Observe the flight carefully
- If the glider flies away from you and glides smoothly for 4 or 5 meters it is trimmed and you can move to catapult launching.
- If the glider's nose rises and then dives during the flight - add a little more nose weight and repeat the trimming flight.
- If the glider dives within a couple of metres from the launch - remove some nose weight and repeat the trimming flight.
Catapult Launching - Caution Dangerous - make sure the launch and flight path are clear !!!
- Hold the very end of the glider by the bit of the fuselage that is sticking out the back.
- Hook the loop of the elastic over the launch hook at the front of the glider.
- Extend the arm holding the elastic band so that the elastic band is stretched to about half its length.
- Aim into wind [ gentle breeze only - strong breezes that ruffle hair or clothes will cause unpredictable flight - do not fly ! ]
- With the nose ever so slightly ( 1 or 2 degrees ) high than the tail and the wings level (horizontal) release your glider while moving your front arm slightly down and out of the flight path.
- Observe the flight carefully - you may need to trim for the additional power see Trimming your glider.
- Once you have practised a few launches you can start to introduce more power by extending the elastic band further.
Experimenting.
Once you are happy with how your glider behaves ( it usually flies in the same way each time ) you can alter the launch angles or tilt the wings slightly off horizontal to see what happens - You should go back to half stretch on your elastic band until you are comfortable with what will happen on the flight and then gradually increase power as you go.
