Xbee Quick Setup Guide (Arduino)
Intro: Xbee Quick Setup Guide (Arduino)
This instructable will help you be able to make your xbee work with your arduino. An Xbee is a small transceiver that sends our serial data that is fed into it. It is very helpful in wireless matters, like data from surveillance, RC toys and more. But if you need to set up an Xbee model, after you know how to do it, its is as easy as 1,2,3.
Submitted by Newton Labs for the Instructables Sponsorship Program
STEP 1: You Will Need
XBee
Arduino
Xbee Shield
Xbee to computer serial
Arduino
Xbee Shield
STEP 2: Hardware
Get your Xbee and put it in your shield and put your shield on the Arduino. Plug the Arduino into your computer, and plug the computer to Xbee adapter into the computer as well.
STEP 3: Send Serial From Arduino
Get one of the sample programs that sends serial data to the computer and upload it to the arduino board.
STEP 4: Digi Program
Install X-CTU from Digi and open it up. Select the com port the xbee to computer adapter is on then press test/query. If it says that you are connected to it in any way then go to the "terminal" tab. See if you see the Arduino's serial. If you do not, switch the modules and see if it works. (X-CTU can be downloaded from this link: http://www.digi.com/support/productdetail?pid=3352&osvid=57&type=utilities)
STEP 5: Done
This was a simple quickstart guide of how to use an xbee with arduino. Thanks If you have any questions ask in the comments section.
8 Comments
SANTAMANYU GUJARI 6 years ago
it would be better if you upload the code,that you have used.
naga swathi 7 years ago
my project is wireless electronic notice board using arduino and zigbee.I have 2 arduino uno boards,2 xbee s2,lcd,10k potentiometer.Transmitter-laptop,arduino,xbees2.Receiver-Xbees2,arduino and lcd. I have to transmit a message from transmitter to receiver. please send the transmitter and receiver code.
thank you
prince ta 7 years ago
I'm unable to understand properly the screenshot including the code, it would have been awesome if zoomed screenshot was captured or if code was copy pasted over here.
kashif.mushtaq07 8 years ago
حمدىش 9 years ago
thank you for your effort ... but i'm not understant all of information about the x-ctu .... i'am interested fot this becaus my graduation project .. thank you
x v h -ch_8 9 years ago
i have two xbees ( S2B) and arduino uno , one xbee connected to arduino and another xbee connected to computer by xbee explorer and usb cable ...i want send data from arduino xbee to computer xbee , can i appear data on serial monitor of arduino ? if no , where data appear
Gabry295 10 years ago
Thanks for the gude, I have a question, how can I send 5 different analog signals from an Arduino UNO to another one?
simonfrfr 10 years ago
You first use the ADC on the Arduino (p = analogRead(A0);) Then you serialize the data. (Serial.print(p, ",");) With that the data is sent to the other arduino and that data can be used for any data processing that you need to do.
