Xbox 360 Slim WiFi Antenna Modification
Intro: Xbox 360 Slim WiFi Antenna Modification
Need to get a better signal from your Xbox 360 Slims Wifi Antenna? Adding another antenna will dramatically improve your Antenna signal receiving strength.
http://www.youtube.com/watch?v=f3EGwdT96ko
Please comment on this tutorial or leave a video of the results you get.
Did you like the tutorial?
Anything to improve the tutorial?
STEP 1: Remove Xbox 360 Slim Wlan Adapter
Remove you Xbox 360 Slim Wlan adapter. If you need help with this use a crowbar, sledge hammer, or whatever (google ) to find and remove your wlan adapter. If you can't do this, then you can;t do the rest.
STEP 2: Remove Xbox 360 Slim Factory Antennas
After removing your WiFi adapter. Remove the factory installed antennas (2)
STEP 3: Install NEW Antenna on Xbox 360 Slim Wlan Adapter
Solder the new antenna socket. I used the Capacitor Side of the trace. Be sure to remove both antennas.
STEP 4: Mount External Antenna on Xbox 360 Slim Case
STEP 5:
Enjoy Neighbors Wifi
12 Comments
CPARKERMA 7 years ago
My WI-Fi tower antenna arrived without the cd disc for using it. Is it possible to find this through your contacts? Will appreciate any help,
xerics 8 years ago
There is a easy no solder solution too, use a MS-156 male plug to RP-SMA female cable and plug into the CON1 connector on the wi-fi adapter. I bought mine from this outfit and it works great.
http://www.ebay.com/itm/2dBi-6dBi-7dBi-9dBi-X-Box-...
Savy1983 8 years ago
msalem5 10 years ago
voltstech 10 years ago
If you need help with the mod email me or leave a comment and i will answer it here.
Okay so I readjusted the image..to not be offensive
nstancil 10 years ago
Thank you for the support. I chose to take it off though. "Please one gain one., Offend one lose many."
caitlinsdad 10 years ago
This is a family site. I would think that image text in Step 5 is offensive and adds no value to your instructable.
Thank you for the reply. I will take the image off.
yokozuna 10 years ago
That's a cold-blooded response. This website needs more... UNITY!!!
My Video With the results is here.
http://youtu.be/f3EGwdT96ko
