Xbox 360 Wireless Controller Carrier
Intro: Xbox 360 Wireless Controller Carrier
In this Instructable, I will show you how to make a 'LEGO Mindstorms' carrier to hold your wireless xbox 360 controller for you while you walk around, (or if you're just waiting for a game to start and you can't be bothered holding it!)
STEP 1: Photos
Here are some Images of me wearing the carrier with an xbox 360 controller in it.
STEP 2: 1
You will need to make the 2 items in the first picture.
The second picture shows the pieces in more detail, before they are put together.
STEP 3: 2
The first picture shows the relevant pieces, the second picture shows how to assemble them.
STEP 4: 3
Add the 2 pieces together that you made in the previous 2 steps, it should look like the image shown here.
STEP 5: 4
Collect the pieces shown in the first image and assemble them as shown in the second image.
STEP 6: 5
Now put the pieces that you have created together in the places shown in the first image, When stood up, it should look like the piece shown in the second image.
STEP 7: 6
Assemble the 4 pieces shown in the first image and assemble them with the other longer piece shown in the second image.
STEP 8: 7
attach these pieces together plus the piece right at the bottom of the image in the centre.
STEP 9: 8
Add the pieces in picture one together to create the item in picture two.
STEP 10: 9
Attach all the pieces together to look like the image shown here
STEP 11: 10
Attach the pieces in image 1 to make the pieces in image 2. then attach these to the pieces in image 3 so that they look like imgage 4. Finaly, add them to the larger piece as shown in image 5.
STEP 12: 11
Cut a small piece of plastic tubing, (this does come with some LEGO Technic and LEGO Mindstorms sets). This piece must fit snuggly between the yellow pices as shown in the second image.
STEP 13: 12
Collect the pieces in image 1 and push them through the carrier in order so that it loks like image 2.
STEP 14: Instructable Completed
You have how completed this Instructable! If you don't have all the pieces, just try to improvise. If you have all the pieces and you have made this, good on you. Now you can try it out, go ahead, put your controller in it and walk around your house. as long as the controller isn't wired, you should be able to walk all around your house with the headset plugged in and talk to your friends.
The carrier can be placed over your belt or hang over your pocket if it is big enough. The two rounded pieces should easily fit over the edge of belts etc.
Don't forget, you must insert the controller into the carrier upside down, as I am wearing it in the picture.
IF the carrier keeps breaking (mine doesn't but I'm sure it could with constant use), I would recommend super glueing the pieces together. (That is, of course, if you don't mind not being able to use them again).
28 Comments
airsoft guru 12 years ago
BklynDJ 14 years ago
wilsonater 15 years ago
reddog92396 15 years ago
ILIKEPIE333 15 years ago
DrWeird117 15 years ago
baneat 15 years ago
SeMi_AuToMaTic 15 years ago
volund 15 years ago
volund 15 years ago
