Yardstick Paracord Jig
Intro: Yardstick Paracord Jig
This tutorial will show how to make a simple Yardstick Paracord Jig made entirely from a....... yardstick.
It uses approximately 32 inches of a yardstick which can be found at your local hardware along with a few other supplies. Its very portable, light and compact. It is adjustable from 4 1/2 to 10 inches. The general idea for this jig was not completely mine, however the use of using ONLY a yardstick is. I have not seen one anyhow. I hope you have fun making this as I did.
STEP 1: Materials and Tools
Materials:
1 - Yardstick
1 - 1 1/4 inch bolt and wingnut
2 - Cable clamps
1 - Side Release Buckle
2 - 1/4 screws
Glue
Tools:
Handsaw
Drill
Drill Bits
Miter Saw
1 - Yardstick
2 - Cable clamps
2 - 1/4 screws
Glue
Tools:
Handsaw
Drill
Drill Bits
Miter Saw
STEP 2: Step 1
Cut the section of yard stick as shown.
This will be the top of the jig and used to
measure your bracelets as you make them.
STEP 3: Step 2
STEP 4: Step 3
STEP 5: Step 4
STEP 6: Step 5
STEP 7: Step 6
Here I used a Square to keep the cut straight and another piece of yardstick to hold the piece I was cutting down to keep my fingers away from the blade. Hold the piece being cut down firmly or it may move causing an unstraight cut.
STEP 8: Step 7
STEP 9: Step 7
STEP 10: Step 8
Predrilling prevents wood from splitting when putting the screw in.
The 1 1/4 inch bolt and wingnut will be used in the next step so the hole behind the clip will need to be drilled all the way through.
In the photo the buckle does not look flush althought it was.
STEP 11: Step 9
Use the 1 1/4 inch bolt to hold the 2 inch piece and the longer bottom piece together. This will be your adjusting screw for make your bracelets. At this point your jig is complete and ready for use. I lightly sanded the edges and with medium sandpaper which is optional, but makes it feel much better in the hand.
48 Comments
BurnerJoJoDancer 4 years ago
AL1EN 6 years ago
Nice! But I do have one question. Why not just cut 2 pieces 13" long (or as long as desired), then only add 2 1" pieces to it?
RuthS88 6 years ago
The reason you wouldn't just cut 2 pieces at 13" is that you need to use the yardstick measurement markings. The first inch markings would be covered up by the 1" piece at the end if you just cut it 13".
ccmain57 7 years ago
This is very cool. I'm going to get the materials and make one today.
Thanks C
chilihook 7 years ago
Crafts101 9 years ago
thank you so much! You just saved me $15
Infidel8654 8 years ago
Only saved you $15 if you already had everything to make this simply lying around the house and you don't figure in the time it takes. To go out and purchase all of the needed parts this is only saving you about $9. During the time it takes to make one of these I can make a few paracord projects and net a whole lot more than $9. And then read all the comments from those who've made this and found out it only works for one size of buckle, so I guess it's good if you only make one thing.
Sickman99 9 years ago
What else can you use besides glue to put the small blocks on the yardstick I don't want to wait for it to dry
cool man1 8 years ago
4eyedjack 8 years ago
DebraK 9 years ago
I made this and don't know what happened. When I added the cable clamps the wood split and fell apart. If this would have worked it would have saved me some money.
JohnnyC4 9 years ago
I glued all of mine and then pre-drill for the Cable clamps holes did not predrill the first one and split and Fell apart to and the boys at my church loves them
Jay1376 9 years ago
SparkySolar 9 years ago
Thank you for the nice instructable
Rima
Hotpinkleg 9 years ago
mung1 10 years ago
Awesome tutorial for such low cost. For people who don't have access to a miter saw can you post example of how that end product would look like, especially the underside of it. Do you also unscrew the clamps when done? Is there another hook that makes it easier to unclasp besides a cable clamp?
thank you :)
timingworks 10 years ago
I believe that you leave the buckles clamped to the jig, using another buckle to make the bracelet. Great "ible" BTW. Does the machine screw head cause the jig to wobble when placed on a table?
TheAntiHeroHimself 10 years ago
Excellent idea! I've got a few yard sticks laying around, I think I'm gonna go try my hand at this!
Im the Doctor 10 years ago
ahirsch4 10 years ago
