Yarn Balloon Easter/Holiday Eggs
Intro: Yarn Balloon Easter/Holiday Eggs
These are super simple decorations for Easter, Christmas, or any holiday you choose. just change the yarn or string and embellishment colors.
STEP 1: Step 1-Shopping List
1-School glue and water (50/50 mixture)
2-Yarn
3-Water balloons
4-Wax paper
5-Medium bowl
6-Some TIME!
Optional-Gloves
Optional-Glitter, Sparkles, Beads, etc
STEP 2: Step 2-Glue Mixture
In the bowl, measure equal amounts of glue and water and mix well until the consistency and look of milk.
STEP 3: Step 3-String and Balloon
Blow up the balloon. Pull out about 5-6 feet of string, depending on the size of balloons you are using. Feed string into bowl of glue/water mixture and get entire string wet. Pull string out of bowl from other end while sliding other hand fingers among string to remove excess glue. This will decrease dying time, make for a neater working area, and make wrapping the balloons easier.
STEP 4: Step 4-Wrap Balloons
While holding the end of the string against the balloon, start wrapping the balloon. Be sure to work in circular motions while keeping tension in the string and wrapping the balloon a little tight.
HINT- Do not make drastic turns while wrapping as it will unwind and fall apart!
STEP 5: Step 6-Set Aside and Let Dry
Place the eggs on wax paper and let dry (depends on amount of glue, but approx. 24 hours).
STEP 6: Pop and Display
When the string is completely dry, pop the balloon and carefully pull it out. Now it is ready to display. You can put candy or other fun stuff inside the balloon before you blow it up. I have not found an easy way to do this yet. if you know of a way, please share.
2 Comments
SamandEllen 8 years ago
It is soooooo cute! Can't wait to get supplies to make some.
Michami 10 years ago
