Yarn Bowstring Silencers
Intro: Yarn Bowstring Silencers
This instructable will show you how to make string silencers out of synthetic wool yarn! It is an effective and inexpensive addition to any archery rig.
I own a Samick Sage 3-piece takedown bow, and I love it! however, because it is a takedown bow (meaning it comes apart into several pieces) it has some extra buzzing when I shoot it from full draw, and I wanted to make it stealthy quiet. Also, this could be used to silence any type of traditional bow, not just a recurve!
This is my first instrucable, so I'll take any kind of feedback!
Lets get started
Lets get started
STEP 1: Materials
Materials you will need:
-Yarn
-Ruler
-Scissors
-a light colored marker or grease pencil
-2 Twist ties
I managed to find a camo colored yarn at wal-mart, and it looks pretty cool on my bow. You can use any color yarn you'd like, and I'm sure you could use 100% real wool yarn if you can find it. It would probably work even better!
-Yarn
-Ruler
-Scissors
-2 Twist ties
STEP 2: Measuring and Cutting
Take your yarn of choice and measure out a segment between 3 and 4 inches. Cut with the scissors and start assembling a neat pile from the 3.5 inch pieces.
STEP 3: Making Bundles
Repeat step 2 until you have a bundle of about 40 pieces of yarn. Then, start over until you have a second bundle containing an equal number of pieces.
Optional: wrap the two bundles near the middle with the twist ties. This will help keep the bundles together when you are trying to string the bow!!
STEP 4: Marking the String
Now, grab your bow. While it's still strung, mark where you want to put your string silencers on the string itself.
There are various methods to string silencer placement, but I decided to measure the length of my bow and then mark about 1/4 of the way from each end of the string.
Some people prefer 1/3, others 1/3 and 1/4. Its up to your personal preference, style of shooting, and type of bow. feel free to adjust these!
No matter the spacing, you should have two marks on your bowstring now, one on either end of your bowstring.
STEP 5: Making a Gap in the String
Unstring your bow. Place your bowstring on a flat surface. Find the mark you made in the last step. Carefully, tease the bowstring apart so you make a small hole between the strands, right in the same spot you made the mark.
Find your other mark, and repeat this on the other end of your bowstring
STEP 6: Adding the Bundles
Grab one of your bundles of yarn. Place the bundle of yarn into the gap you made in the string, making sure it is centered around the mark you made on the string.
Then, gently twist the bowstring to lock the bundle of yarn securely between the strands of the bowstring.
STEP 7: Stringing Your Bow
Now take your bowstring with the yarn bundles twisted into it, and string it like you would normally. From here, you're pretty much done! they look a little silly right now, but as you shoot your bow, the yarn will begin to fray, and will puff out. This will make them look much better and also create a more effective silencer.
Just strum the string a few times and see what I mean, they'll begin to fray and start puffing out
STEP 8: Enjoy!
After a couple weeks of usage, they will be completely frayed out. If you want, you can carefully take your scissors and trim the silencers into spherical shapes to make them sleeker looking.
Thanks for reading! Enjoy your new stealthy bow!
12 Comments
robolimbo 9 years ago
Great twang tamers!
Rambo556 10 years ago
How would you make this if you have a paracord bow string?
rstämpfli 11 years ago
Another cheap n easy tip for hushing these things up a bit is to get some of that stick on velcro tape- use the softer, fuzzy 'female' part and tape it to the ends of your bow's limbs so when you send an arrow away the string doesn't slap the the limb as hard - it's supposed to increase the life of the limb as well as quietening your shot.
bit of stick on felt to the shelf (if you aren't using a rest) will kill any noise of tapping the arrow against it when moving with a knocked arrow too
- again, thank you!
joey99 12 years ago
radagast 12 years ago
joey99 12 years ago
Mr.1911 12 years ago
joey99 12 years ago
