Your First LED
1,560
Introduction: Your First LED
This was also my first led. Super easy to make, I got all the parts from my local Radioshack.
Its quite bright depending on the amount of solar energy provided!
This is not my best instructable to be honest, The way to get power can be subsituted.
 -9mvp9
Step 1: Materials
There is a question that must be faced before starting:
What led color do you want - I chose red. as long as the led has a positive and a negative wire out the end, it works.
Solar, or battery power - I chose solar just to test it. If you can find a good battery pack that packs enough volts without breaking the LED and has a positive and negative wire, You're safe.
Once you faced these questions, you can get these parts, and start building
Step 2: Assembly
Tie the red wires together and the black wires together. Add the electrical tape to secure the bond.
Step 3: Finished, Wasn't That Simple?
Wasn't that simple? I went $17 dollars into the hole due to the solar. but otherwise, this was a easy instructable. Thank you for reading this instructable.
LED Contest
LED Contest
Be the First to Share
    • Make it Glow Contest
    • First Time Author Contest
    • PCB Challenge
      PCB Challenge
    7 Discussions
    freethetech
    freethetech
    9 years ago on Introduction
    Welcome to the world of electronics! You're next job is to wire the solar panel to a battery so that you can use it at nighttime! What's the point of an LED if it's bright out? Good luck!
    9mvp9
    9mvp9
    yeah. I was thinking about doing that. Good point also.
    sauwen
    sauwen
    Seems careless without a resistor unless you know for sure the output of the solar panel won't fry your LED.
    94todd
    94todd
    i have bought those kind of LED's before from radio shack, i believe that they come with a resistor built in
    9mvp9
    9mvp9
    I am new to this! Lol. I am working on a better version
    freethetech
    freethetech
    I can't believe I forgot to mention that! Yeah, even just a 500 Ohm resistor would do you good for an LED. I generally use 1k volts, but vary depending on the project.
