ZDW 50V 3A PNP SMD Transistor
Intro: ZDW 50V 3A PNP SMD Transistor
ZDW 50V 3A PNP SMD Transistor. || ZDW SMD Transistor Price.
PNP low VCEsat transistor in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package. NPN complement: PBSS4350T.
plastic, surface-mounted package; 3 terminals; 1.9 mm pitch; 2.9 mm x 1.3 mm x 1 mm body
Features :
- Low collector-emitter saturation voltage VCEsat and corresponding low RCEsat
- High collector current capability
- High collector current gain
- Improved efficiency due to reduced heat generation
- Type number: PBSS5350T
- Marking code: ZDW
STEP 1:
Limiting values :
- VCBO collector-base voltage open emitter - 50 V
- VCEO collector-emitter voltage open base - 50 V
- VEBO emitter-base voltage open collector - 5 V
- IC collector current - 2 A
- ICRM repetitive peak collector current δ ≤ 0.25; tp ≤ 100 ms - 3 A
- ICM peak collector current single pulse; tp ≤ 1 ms - 5 A
- IB base current - 0.5 A
- Tj junction temperature - 150 °C
- fT transition frequency: 100 - MHz
