Zippo Trick: the Twilight Zone
Intro: Zippo Trick: the Twilight Zone
Want a dirt simple Zippo trick that will amaze people again and again? Then try out this one called Twilight Zone. All you need is a Zippo lighter and a few minutes to practice.
I've seen this done before on different sites so I didn't create it. I'm just showing it so that more people can know about it and get free drinks at bars from their friends.
STEP 1: Prep Your Lighter
Getting your lighter ready for this trick is easy. Stick your pinky finger or a pen inside the lighter and curve the wick towards the hinge. Just make sure that the lighter hasn't been used recently or you'll burn yourself, OK?
Curving the wick creates a small pocket where a smaller blue flame can still burn even while the main flame has been put out.
Easy, right? Now let's do it.
STEP 2: Pinch the Flame
First of all, make sure that you're indoors and there's no draft. This trick can live and die by air circulation.
So light up your Zippo and pinch off the flame. This is done by putting your thumb and index finger together and closing off the flame by moving them across the top of the chimney.
If you do it right, you'll see a small blue flame caught under the curved wick. If it's not working, tilt the lighter a little bit to the outside and try again. This gives a better angle for the wick and makes it easier for the flame to get caught.
If you're still having problems, try adjusting the wick again. Just make sure to let the lighter cool off before you touch it.
Assuming you have the trick going properly, talk about how you're holding the flame in your hand, how cool Prometheus was, or whatever else to keep the suspense going.
STEP 3: Bring the Flame Back
Getting the flame to reappear is as simple as giving the lighter a tiny shake. This will jostle the flame enough to let it spread and burst out the top of the lighter.
To distract anyone watching, make some movement with your other hand. Open it up so it looks like you put the flame that you were holding this whole time back into it. Or you can snap your fingers. Or say "redrum" really frickin' loudly. Make something up.
STEP 4: Look, No Hands!
For a variation, place the lighter on a table and carefully pinch of the flame. Leave it alone and to light it back up push your hand right up to it. The air movement will light it up again.
Enjoy!
Enjoy!
267 Comments
BrownClown 5 years ago
Badetise 11 years ago
normanthybeast 12 years ago
atan18 12 years ago
fungus amungus 12 years ago
sassimo03 12 years ago
gnartkoshvili 12 years ago
oscarwindahl 13 years ago
joekickass345 16 years ago
sharlston 14 years ago
weaponscollector94 14 years ago
nerfer192 13 years ago
weaponscollector94 13 years ago
awesomekitteh 13 years ago
if you are ten you are to young to be on instructables so you had to lie abot your age so you lied about your age
sharlston 13 years ago
HardCoreHacker 14 years ago
Archive555 15 years ago
Rokko8652 15 years ago
