Zvs Sstc Tesla Coil
Introduction: Zvs Sstc Tesla Coil
About: I like doing random electronics high voltage projects
120 volt driven zvs sstc tesla coil
Step 1: Schematic
the first schematic is very similar to the second except mine has been adapted do 120 volts and operation of the tesla coil i just included the second one to give an idea of what to build as the first looks crazy
for this project you need need: 2 fqa19n60 power mosfets (easily got from ebay)
2 100 ohm resistors
2 diodes (most recommend ultra fast diodes however in my experience they make the performance worse than if you use standard rectifier diodes)
the inrush inductor {L2} (should be an air core inductor with very thick wire
the primary coil (this can be made with copper pipe (mine is a 6 inch 1.5 turn on each side of the center tap))
resonant capacitor (this is critical that you get it right otherwise it may catch fire or explode...you have been warned. i recommend a oil can type at 50 nanofarads)
secondary coil (my coil is a 4 inch tall by 3 inch in diameter)
transformer for the 15 v gate drive (aswell as a half bridge rectifier and capacitor (basically make a 15 volt linear power supply for the gate drive)
Step 2: Video of Operation
more videos of this can be found at this youtube channel (aswell as a place to ask questions(the comment section)) : https://www.youtube.com/user/neallkennedy
Be the First to Share
    • Crayons Challenge
      Crayons Challenge
    • Halloween Contest
      Halloween Contest
    • Cheese Challenge
      Cheese Challenge
