A Plastic Community Aquarium
Introduction: A Plastic Community Aquarium
Previously
I had a glass aquarium but, in the cleaning process the bottom of the aquarium had broken and I decided not to use the glass aquarium in future, so I shifted to plastic tub of total capacity of 40litres with a height range of 40cm. In which the level of water in my aquarium is up to 32cm. The total water capacity in the tank is 7 gallons. Here I am showing the process of my community aquarium
Step 1: Materials and Tools Required
Step1:
Materials needed: Plastic tub
Mechanical filter
Gravel of two types
Medium gravel of size 1-2cm
1kg of white stones
1kg of color stones
Small gravel of size 0.2-0.6cm
Fine sand of 1-2mm of ½ kg
Black soil of 1kg
Composite soil granules of 200grams
3coconut shell of different sizes
Chlorine remover
Bore water
One large stone of weight 500grams of length 8cm and thickness of 2cm
Two medium stones of 100 grams 2cmlength and thickness of 2cm
Sponge filters without sponge
Voltage regulator
Dc charger
White Led light strips 3*8-1
White Led light strip3*4-1
Green led lights2
Blue led lights 4
Gate switches 2
TOOLS REQUIRED: Sand papers of different grades
Soldering gun
Soldering flux
Soldering wire
2 sided foam tape
Step 2: PREPARING THE AQUARIUM
first take the plastic tub and clean the tub with vinegar solution and then dry it in the sun for 3 hours. take the black soil a pack of 1 kg and bake it ata temperature of 130celsius and then cool it at room temperature and then mix with composite granules and sand place a half inch thickness in the plastic tub and thean take the white gravel of medium size and form a layer of thickness 1cm on the soil, again with the use of short gravel form a layer of gravel bed on the soil, the total bed thickness is of 1.3inch
Step 3: FORMING CAVES AND ARRANGING STONES
FIRST I HAD TAKEN THE COCONUT SHELLS FROM MY COCONUT FIELD AND THEN REMOVED THE OUTER AGENTS FROM THE TOP AND INNER SIDE OF THE SHELL WITH THE HELP OF SAND PAPER, AND THEN SHELLS ARE MADE TO BOIL AT 100 DEGREES CELSIUS TO REMOVE THE TANINNS FROM THE COCONUT SHELLS AND THEN MADE THEM TO DRY IN SUN, AGAIN THE BOILING OF THE SHELL IS DONE UNTIL THE WATER LOOK LIKE A CLEAN WATER.
NOW THE TANNINS FREE SHELLS ARE TAKEN AND WITH THE HELP OF DRILL BIT I HAD MADE HOLES AND ONE LARGE ENTRY HOLES ON THE TOP AT THE LARGE SHELL, 3 HOLES ON THE TOP OF THE SHELL AND ONE ENTRY HOLE ON THE SIDE OF THE SAME SHELL
NOW TAKEN THE STONES AND PLACED THE TWO MEDIUM STONES ON THE GRAVEL BED AND PLACED THE LARGE ON THE 2 STONES IN THE CAVES
Step 4: FINISHING TOUCH
POUR THE WATER IN THE
Step 5:
Be the First to Share
    • Anything Goes Contest
    seamster
    seamster
    8 years ago on Introduction
    The fish look happy in their new home! Thanks for sharing this.
