Bicycle Chain Handle Knife
Intro: Bicycle Chain Handle Knife
bicycle chain handle knife
a broken, unused knife blade, and an oily bicycle chain born out of marriage ...
1.
It was the bottom of the blade with two holes
was fitted to the chain pin, hammered together
-----------------o _._._._._._. _._.
blade hole chain |
--------------- o_ _._._._._._._._. |
2.
I finished welding the holes
3.
3 chain piece is cut off, and gradually from top to bottom "sewed"
more idea would be to handle the development of
U-shaped hollow center
porous
___________
___|___|____|
the most exciting,
resin poured in the holes
sanded and polished
transparent handle
1.
blade hole chain |
2.
3.
porous
___________
___|___|____|
the most exciting,
sanded and polished
transparent handle
26 Comments
joram2000 8 years ago
such a cool idea its looks cool as wel so well done
bakdrft 10 years ago
Vitizop 10 years ago
handle ~ 15 cm ~5.9 inch (part three , in all 45 cm ~17.71inch)
you may want to experiment with the length of the handle may be better on the shorter, gravity distribution is better
to taste
Bones3007 10 years ago
Lochtar 11 years ago
With all good intentions. ;)
No, seriously I really love idea. But it look messy and it gives me an idea how to make my own version.
I will make mine out of a simple pocket knife.
With this kind of principle:
http://img.symworks.com/l_skeleton_knife1.jpg
And then try to make it work. :)
brettj1 11 years ago
Vitizop 11 years ago
thin the chain should be thicker
can not be controlled min: 50A
For almost burned the chain
I haven't tried it on a stick welder but I think it would work the same. you might be able to get a neater weld. You could also try welding spots on the edge of the chain links to lock the links & use small welds on every 2nd or 3rd to hold the strips together then you can grind them smooth after.
I often make 2 of most things I make, the 1st a prototype I'm never happy with because I see the mistakes I have made & the 2nd, I make changes so I get a neater job just some suggestions I hope it helps
southbayrik 11 years ago
t.rohner 11 years ago
yugioh54444 11 years ago
desertsniper 11 years ago
Questor 11 years ago
the balance is the lower third of the shaft
nofx_l 11 years ago
Pero en la clase donde yo cosida a este hombre poco
- La mano, que es la soldadura -
what is the heft like?
acoleman3 11 years ago
germeten 11 years ago
