Bike Rim Resurfacing
Intro: Bike Rim Resurfacing
Resurface bike rims for up to 300% stopping power, even in wet conditions. Makes some bike brakes impervious to water, even submerged....
STEP 1: Get Some Slate First
get a sample piece of slate used in construction....Slate is a grindable and fileable sedimentary stone, and is almost as hard as granite....an ideal chioce for a resurfacing stone on aluminum up to cast iron....
STEP 2: Cut Slate With a Suitable Tool
To cut slate, you neet to user a suitable tool and cut it with water as a coolant and lubricant. In this case I used fiberglass-reinforced cutoff wheels for a Dremel tool. This is Black & Decker part #RT1000 (426)....Be sure to round the wheel on a piece of scrap before you proceed to cut, and do not remove the wheel after doing so unless it is worn-out or shattered....but these wheels are supposedly shatterproof...
Nonetheless, always wear eye protection and do not cut or grind directly into your face
STEP 3: Prepere Slate for Cutting
Have a suitable jar handy filled with water so you can dip it in and keep the stone soaked. Quench (dip) the slate before it dries out from the friction. Keep the stone wet as you cut or it will flake and chip and chew up your cutoff wheel prematurely. Room-temperasture water will work just fine, just keep it wet through the entire cutting process...you cannot keep it too wet for cutting, in case you had any doubt, and not only controls dust, but keeps everything cool and lubed enough...
STEP 4: Cut Your Stone to Desired Size
Never force the tool, let the tool do the work, excess pressure is not necessary and will wear down your tools prematurely...The ideal speed for this is somewhere around 20,000 rpm, but you can cut at full speed if your rotary tool is not of the adjustable type. Do not cut in one place, just keep recutting the same groove over and over. As soon as the stone starts to dry around the cutting area, dip it again....beware the initial water spray as this will contain some of the slate particles which will be very unfriendly to the eye socket mechanism, hence the need for safety glasses at all times....
In this example I cut a small stone..I have cut larger stones for other purposes, but this is to give you the general idea...
STEP 5: Now, Lathe Your Bike Rim
In this step, you will be lathing your anondized (coated) bike rim with the stone to provide a better braking surface. Note how I am holding the stone at one end...The wheel in this pic is rotating clockwise, with the pressure being put on the trailing-end of the stone. Be sure that the stone is filed flat on the surface you intend to use for honing...
Keep spinning the wheel manually while holding moderate pressure on the stone the entire time. eventually you will notice the anodization being scoured off, leaving bare aluminum...It is ideal not to let the wheel come to a complete stop in this process, as the stone will get a little clumsy on the recoil...
STEP 6: Note the Technique Used
Note how I am using my right hand to spin the wheel and my left to secure the stone, using the bike fork as reinforcement. Hold the stone tightly so it doesn't get away from you, and be sure to over the entire side area of the rim by both moving the stone up and downb on the rim as you hone it, and placing it diagonally in both a toe-down and toe-up direction....Once you see a roughened surface, you know you are close to hiome....lighten the pressure once you see bare aluminum to hone the last of the anodization off...
Do this type of honing dry, you want some of the scoring, and some of the aluminum to collect on the stone to add to some of the abrasion. This methiod will also smooth the rim surface for more even braking throghout the rim's rotation...
STEP 7: After Removing All Anodization...
Wipe the rim surface down with a clean, dry, disposable cloth to remove the excess dust, and then go for a ride, favoring the brake you just refinished for stopping to reseat the pads. This method can be repeated for when rims get glazed, but the advantage of this is that it gives a 400-grit sandpaper finish every time, without wasting sandpaper....
Now your aluminum bike rims will have much better braking power, even in the wet. This method has been tried-and-trued through just about all conditions, even completely submerged, so I suggest any with halfway-qaulity bikes to try this on their rims...
Just be sure to test braking power moderately at first, especially on the front, as this is what it is recommended for. This method is most ideal just before using the olegendary "Scott-Matthauser" brake pads, which you will find in orange...Following that, you will have bike brakes suitable for stopping a 3000lb car....
The finish you see is what you want to aim for...
32 Comments
dwosullivan 13 years ago
bad ass pope 14 years ago
Thanks.
Prometheus 14 years ago
Yes they are. Caliper brakes are weak and flexible, and rubber and steel are easily parted by a layer of water. Some will even tell you that they are downright dangerous in the rain, and to them I agree. The first way to make sure your brakes are working at their peak potential is to keep your wheels "true" (straight), and set your brakes properly on the rim (I think there's an Instructable on how do do this on this site somewhere). When squeezing the brakes, the front part of the pad should touch the rim first, and the pad should "land" squarely on the rim under hard pressure while the wheel is rotating. Maximum braking power should be achieved without the brake lever coming close to touching the handlebar-grip. For caliper brakes, the calipers shouldn't wobble, but also shouldn't be "sticky" (it's a terrible design, really).
Something you can try is to roughen the rim a little. What you need is a portable drill and a grinding stone (gray-wheel) on it. Using the same method as with the wire-wheel, hold the wheel at a 45-degree angle relative to the braking surface (when looking at the wheel from the side) and use the drill to spin the rim, like the pic below. Don't put too much pressure or you may grind too deep and weaken the rim. As the wheel turns, the grinding stone will draw a line around the rim. It doesn't have to look pretty, it's more effective when it isn't.
The idea is to scuff the rim diagonally so the pads have a little more to bite into. Be careful not to grind too much, you just wanna ugly that mirror-finish so your brakes will work. Wet performance will almost exist, and dry performance will improve.
If for some reason above is not an option, an even quicker and dirtier way is to cut some durable and coarse sandpaper to cover the pads like little booties, and ride the bike while holding the brakes down lightly (be sure you aren't sanding the tires!) to score the rim surface. This is even less effective, but it's better than leaving them the way they are. Be careful as your braking power will be dramatically increased while doing this, so don't honk on the brakes hard or go too fast. This can be a good thing, but using this for a fix would eventually cause a blowout by grinding the rim away.
Above all, NEVER wax the rims, and try to keep them clean, because oil from car exhaust and just on the road can gather on the rim surface, and eventually the pads themselves. Don't use the pads that were on the back wheel on the front, because they are likely already contaminated with oil from the chain (not to worry though, any more braking power and the rear wheel locks anyway). If your pads are glazed, use a file to take some material away and get rid of that shine. Using a hacksaw to cut 2 or 3 shallow slots diagonally in the pad should give water someplace else to go. Observe wheel rotation and cut the slots so that when installed, they angle opposite the angle of the front forks so that they sling water outward from the rim.
Don't cut too deep (maybe about 2mm or so), and don't cut too much. Too deep, and the pads will deform under braking. Too much and you won't have enough surface-contact for braking.
If you can afford it or are otherwise willing, replacing them with aluminum rims would be best (or at least the front, where 85% of your braking is). They are lighter, faster ("an ounce off the wheel is worth two off the frame"), and more durable than steel wheels.
Karletto555 14 years ago
Subfightr 14 years ago
vadvaro 17 years ago
trebuchet03 17 years ago
Prometheus 17 years ago
leebryuk 16 years ago
Prometheus 16 years ago
kill-a-watt 15 years ago
Prometheus 15 years ago
Calorie 15 years ago
