Silent Dorm Heater 250 Watt
Intro: Silent Dorm Heater 250 Watt
Good morning. This is a simple design to give a more stable platform to the common "brooder clamp" light, for people who want a warm (literally and with regards to the color spectrum) light to get going on cold mornings when days are shorter. For people who have "seasonal affective disorder" or just need some more light to be happy, this is something that can be made with common materials. (It is made of a cheap brooder clamp light, milk crate, metal zip ties or pieces of metal wire.)
STEP 1: Simple Construction
Please find a milk crate the honest way. I got some when I worked as a truck driver, when I delivered to milk companies. They had many that were damaged in some way or so dirty it wasn't worth their time to clean them, and they let me have a few for asking. You can also buy them at WM dept stores, craft stores, Amazon or Ebay, or sometimes a gas station will give you one if you ask nicely.
To summarize this instructable, suspend the clamp light inside the milk crate, by anchoring the clamp light deflector at 4 points, preventing any contact with the ceramic lamp base, and protecting the cord by zip-tying or taping it to the crate.
To make this product, first remove the wing-nut clamp and save it in case you want to use the clamp light another way later. Now, simply run the power cable through one of the lattice holes on the side, near the bottom. You can remove the wire "guard" that normally comes with the clamp light (which inserts into the four holes on the lamp shell/deflector). This will give you four holes to mount it with. I recommend removing the bulb, and drilling four new holes opposite the original holes, in about the same size. Then you can leave the guard intact. The guard can become very hot, but may prevent something from falling against the bulb. (Chicken clamp lights have well-known fire hazards. Do not neglect to study them and secure your device.) With four mounting holes in the shell, you can use steel or aluminum wire, or even copper wire if it's not stranded wire, to attach the shell to the milk crate. You can attach it to the handles, or "catty corner" to the lattice holes. Be sure the shell is suspended so the lamp base does not touch the cord or the milk cube. With a 250 watt heat lamp bulb, mine stays cool enough I can hold the lamp base in my hand, as long as the light is directed sideways, or upward. If the light is suspended with the bulb hanging downward, the lamp base will get very very hot (could burn to touch).
STEP 2: Use and Cautionary Warnings
This lamp is very versatile. I like putting it on the floor in my laundry room, with the lamp facing up, while putting up laundry. (make sure nothing falls on it) It adds gentle heat and a nice light almost like a fireplace, without needing any other lights. I like to put this in a safe place while I sit and eat breakfast, so I get some rays while having my coffee and reading a book or checking the news.
If you just want it for a work light, you can save the heat lamp bulb and replace it with a 40 watt "globe" style bathroom bulb, a 60 watt generic bulb, or a 75 watt "garage light" or "utility" bulb. These have built in reflectors and bright white light, and also do create noticeable heat in a cool room. With an LED bulb, this can be a pretty efficient work light and much safer (much lower heat). There are some LED household and porch bulbs for $10-20 that can blast light! I have a "100 watt" equivalent LED with a heat sink, and it shines the whole yard!
Heat lamps create heat, through infrared waves. The heat they create builds cumulatively, and can ignite paper or curtains, or your pants if you sit too close for too long. If you can use a toaster oven, you can use this. :-) Don't use around babies or pets, same with all clamp lights.
Don't suspend over bedding or carpets, and don't leave unattended.
With a 40 watt bulb, or even a CFL or LED bulb, you can use this in your yard, with an extension cord, strapped to a tree or something secure, as a remote porch light or camping light, to draw annoying bugs away from your doorway. Make sure the bugs can fall out of the reflector if they die in there, so they don't plug it up or burn.
6 Comments
Yard Sale Dale 8 years ago
With this outlet switch, you can leave the light plugged in and just turn it on/off at your convenience.
http://www.homedepot.com/p/QVS-Single-Port-Power-Adapter-with-On-Off-Switch-PA-1P/205569217 $3 .
These have been great! I've been making them for outdoor cookouts, fishing lights, varmint lights, bathroom heaters, chicken coop lights, and junebug lights (the bugs fly into the light instead of the house/porch). This is a practical gift item. I have found these switches at Home Depot:
This is still working well, but I recommend cheap LED household bulbs if you want to use it for a floodlight outdoors. I have one for a heat light, one for a chicken light, and one as a flood light for the yard.
Yard Sale Dale 9 years ago
I've got one of these that I use as a garage work light and bug light. I set it on a timer and all the dang june bugs go burn their biscuits on it instead of bothering me. Its using the 75w garage light bulb.
That wasn't fun. lol. I tried a couple light coats of white paint on a heat bulb, to "frost" it. It did tone down the light, but when it got hot, the bulb cracked up. Oh well. Just buy the red factory one if you don't want super bright light.
RED coated heat bulbs. The regular ones are $5 to 10. The "shatterproof" ones (coated in high-temp plastic, to prevent shards if broken) are $10-20 http://www.backyardchickens.com/t/149092/red-heat-bulb-vs-infrared-bulb/10 The 75w or 150w ones will give detectable heat you can feel from a few feet away, and add heat to a room the same way, similar to a large candle or small propane personal heater.
"reptile heater" and other bulbs and clamp lights. http://www.petmountain.com/product//11442-105644/zoo-med-zoo-med-repticare-ceramic-infrared-heat-emitter.html
