Bubble Lamp
Intro: Bubble Lamp
i made this lamp in my first year of highs school, i wanted a lava lamp but without the color so it would be easier to read under its light. i reconstructed the lamp earlier this year since the first base for it wasn't i deal because when i built the lamp i didn't have the ability to weld.
i call it a bubble lamp and not a lava lamp because in its off state the "lava" sits at the top of the bottle, but as it is turned on and heated the wax sinks according to the room temperature and remains a static bubble.
you will need:
+ power plug
+ switch
+ glass bottle
+ metallic bottle holder (angle iron)
+ rubbing alcohol
+ paraffin wax
+ 30 watt globe
you will need:
+ power plug
+ switch
+ glass bottle
+ rubbing alcohol
+ paraffin wax
+ 30 watt globe
STEP 1: Base & Switch
switch
you could go with the easier option of using a cable mounted switch. but i enjoy making mechanisms and creating more work for myself. so i went for creating a rotary switch using a brass knob from a drawer. i threaded a bolt into it and welded a washer off center to touch the switch, the video should explain.
base
the base can be made out of whatever you want i used wood because it has a nice finish and made it much easier for me to router the shapes to create my switch.
Video
invalid movie: http://www.vimeo.com/5487773
base
STEP 2: Bottle Holder
i made the bottle holder before i was able to weld, so i simply used 3 pieces of angle iorn and some bolts to hold it all together. there are a series of bolts the arround the base of the bottle to stop it falling through the holder.
when designing the bottle holder you should consider where and how you are going to place the light bulb holder. the light bulb should be about 5mm to right against the glass of the bottle, it needs to be close to conduct heat. if you plan on using a cylindrical bottle you may be lucky enough to find a section of steel pipe or something..
STEP 3: Liquids
go to your local chemist and ask for some rubbing alcohol and paraffin wax.
the paraffin wax makes up the bubble the rest of the liquid is rubbing alcohol, or you could use any kind of pure alcohol here. the alcohol is potentially flammable so try not to spill it on live wires ect.
there is no right or wrong mixture, so long as the bottle is mostly alcohol you lamp should work fine.
STEP 4: Bubbly Reading
enjoy your new clear bubble lamp.
38 Comments
surfreak 13 years ago
DRAGUA1979 8 years ago
The nerdling 12 years ago
Omni DIY 13 years ago
lime3D 9 years ago
Nope. That' how they work. Google it.
Omni DIY 9 years ago
Clearly that is how they work... the question is whether there is something less... explody.
cdalton4 11 years ago
Michael_Bell 11 years ago
ryanninjasheep 13 years ago
NinjaFixedIt 13 years ago
fabiyamaue 14 years ago
rmart 14 years ago
[insert username here] 14 years ago
cmallouf 14 years ago
wrs715 14 years ago
asasklfjklasfkljasklfjaklfsjkl 14 years ago
Video
King_Changus 14 years ago
jovino 14 years ago
