Camping Light Up Slippers Hack
Intro: Camping Light Up Slippers Hack
Camping with these homemade camping led light up slippers will protect your feet and toes while they light up the way to the bathroom in the middle of the night while camping.Its a simple but brilliant idea to save those toes from harms way.
STEP 1: Materials
(1) a pair of thick fuzzy slippers
(2) two led car key lights
(3) Thin wire for led wire extensions from a diode bought from Radio Shack
(4) needle and thread
Step 1~ disassemble the led key lights from the key ring.
step 2~ set aside the key rings you wont be needing them
Step 3~Save all parts from the led assembly .
STEP 2: Modifying the Led Slipper
Step 1 ~ Take a razor blade and cut open the front of both slippers .
Step 2~ Take a Dremel and bore a 1 inch hole about a 1/4 inch deep where the big toe would be .
Step 3 ~ Drill a 1/8 inch hole through the front of the slipper into the hole you just made with the Dremel.
STEP 3: Modifying the LED
Step 1~ Cut (4) 1 inch pieces of wife from a Diodes.
Step2~ Solder the (4) 1 inch pieces of wire to the (4) ends of the (2) LEDS.
Step 3~Cut (4) 3/4 of a inch pieces of 3/32 diameter shrink tubing.
Step 4~Put 1 piece of shrink tubing on each end of the LEDS and use a lighter or heat gun to shrink the tubing over the wire
STEP 4: Assembling the New Led
Step1~ Connect the battery to the led to make sure the positive wire is on the positive side of the battery.
Step2~ Assemble the new led back into the case it came in and test to make sure it works properly.
STEP 5: Installing the Led in the Slipper
Step1~ Slip the led through the hole made with the Dremel so the led sticks out the hole in the tip of the slipper.
Step2~ use a little silicone underneath the led button before playing it in the slipper .
STEP 6: Finish the Job
Take a needle and thread and sew the ends of the slippers shut and test the lights to make sure they work and your finished ..
9 Comments
rvstealsanddeals 9 years ago
When I first clicked on this article I was wondering what in the world you would do with the lights and slippers. It makes total sense! In fact we have a new puppy we are training in our RV and I have to constantly watch where I'm walking in the night to take her out without turning lights on to wake up my wife. Thanks for sharing!
PikeMinnow 10 years ago
Great 'ible ;P
coolbeansbaby68 10 years ago
flashj 10 years ago
PaHalloweenFreak 10 years ago
Ajnussey 10 years ago
