Chain Maille Hacky Sack
Intro: Chain Maille Hacky Sack
how to make a unique hacky sack
STEP 1: 1
You will need:
2 pairs of pliers
252 5/16" rings
2 1/2" rings
something to fill it with
First make a 4x24 sheet
2 pairs of pliers
252 5/16" rings
2 1/2" rings
STEP 2: 2
make triangles on the edges , leave a open space in between them
STEP 3: 3
connect two triangles together with a single ring
do that to all of them on each side
STEP 4: 4
connect the ends together ,i found using a pipe makes it easier (sorry about the blur didn't notice it until i was done)
STEP 5: 5
connect the end triangles together then run the 1/2 ring through the rings on the top do the same to the bottom
STEP 6: 6
stuff the ball with fabric or any thing else , i found using a screwdriver to push it in through the top works good
142 Comments
hackysack420 10 years ago
Grey_Wolfe 12 years ago
The first two I did with 18g 3/16" rings. It makes for a hacky sack the size of the small ones you can get in bulk. I filled those with knots made from the same rings.
Now, speaking of redundancy...
The most recent version I used 18g 5/16" rings like shown in the pattern to make the outside. When I was finished the weave looked to loose to me. So I made another with 16g 5/16" rings and filled it with the previously weaved empty shell.
Not only does it have a nice smooth look to it, using the previously weaved shell gives it just the right amount of fill (not too full or floppy). Also, using the weaved shell as filler keeps the fill from settling too flat.
Total rings used:
254 - 18g 5/16" bright aluminum (fill)
254 - 16g 5/16" bright aluminum (shell)
(I don't use half in rings to close the ends.)
dany man148 14 years ago
curious youth 12 years ago
dscherer1 12 years ago
big-jamie 14 years ago
NOTE: instead of 24x4 i done 24x2 sheet as i wanted to finish quickly =P
zen of zappa 12 years ago
big-jamie 12 years ago
mofunnyman 13 years ago
Trace II 13 years ago
LastMemory 13 years ago
Kaiven 16 years ago
jehan 16 years ago
Kaiven 16 years ago
killerAP 15 years ago
armourkris 14 years ago
killerAP 13 years ago
