Cheap and Easy Guitar Pickups
Intro: Cheap and Easy Guitar Pickups
here is a little tutorial about improvised guitar pickups
made from easy to find junk
STEP 1: Pickup Basics
simply a guitar pickup is just a coil of insulated copper wire with a magnet in the center.
most things that seem simple dont always turn out this way but here is an exception(sort of).
now im not recomending that you rip the pickups out of your strat and replace them with the herein mentioned contraptions. but if your building a diddly bow or a frankenstein guitar or just looking to make a new noise then thise is for you
STEP 2: First a Real Pickup
here are 3 pictures of a very broken ( and very crappy before it was broken) fake humbucker pick up. it came out of a 1 dollar yard sale guitar nuff said.
if you look closely you can see the basic parts a copper coil of #43 magnet wire wrapped around a plastic bobbin with a steel bar that slides up inside it and a bar magnet that attaches to that.
when a steel guitar string is vibrated near the poles { screws that screw into the steel bar} it generates a very small electric current in the copper coil {similar principle to how a generator/ motor works... hmmm i wonder if you can use a motor...heh heh ill have to try that one later} this small current is what is fed into your amplifier and pumped out the other end greatly amplified.
STEP 3: Experiments Ive Tried and Rough Results
now before we start none of the following pickups have as good {loud} an output as even a mediocre real guitar pickup but some of them are surprisingly good.
now pictured here is the solenoid pickup i made for the 3 string slide guitar thats been featured on this site a while back.( i didnt remove it for a closer look as its hotglued in place and i dont want to break it)but it is a coil that was found in the filter paddles of an old one hour photo printer{i know thats not common junk but copper coils are everywhere} a magnet from an old car stereo speaker has been positioned in the centre{wrapped with a bit of vinyl tape to make a nice tight fit}
the two leads from it run through the back of the guitar to a 1/8 phono jack near the end .
plug it into your amp and get it within about half an inch of a vibrating guitar string and you will hear it .
its a little quieter than a real pickup but it works
STEP 4: Circuit Breaker Coil
this one came out of a old circuit breaker from a large 220 volt machine
the coil as you can see is covered with a hard plastic{bakelite} casing and screw on contacts for the wires.
when in use an iron core fits into it as you see in picture 2.
flip it over and add a hard drive magnet in the center and it acts as a pickup not as good as the first one but it does work.
it also looks like you could fit it into a regular guitar easier too {not that you want too of course}
STEP 5: Water Valve Solenoid
this coil is another plastic covered one and it comes from a solenoid that opens a water valve{ washing machines and dishwashers maybe likely sources}.
in it i have glued a section of a steel bolt because i didnt have a magnet of the proper diameter to put in it but to magnetize it i just slapped a hard drive magnet onto the bottom end(it doesnt matter which one but then it becomes bottom}.
your getting the idea now plug it into the amp and twang away.
STEP 6: Buzzer Coil
this coil came from a ordinary buzzer such as you might find on a dryer or washing machine or used as an alarm on industrial equipment.
as you can see i have it wired to a cord to test and yes it did work but only one way.
again the magnet is from a hard drive{gotta love 40 meg drives}
the third picture here is of a coil that did work but very faint and thats because theres just not enough copper wire in it.
length of the wire is the deciding factor a suitable coil can be made from any thickness wire but the bigger the wire the larger the coil needs to be{house wire pickup would be is as big as a volkswagen}.
STEP 7: Yet Another Solenoid
if you notice most of the coils i have tried have come from solenoids.while im not sure where this one comes from it works too but its kind of tall for use as a guitar pick up
you would have to have one of this type centered beneath each string because its so narrow
the wider fat coils like the first one i showed covers two or three string easily
but you can wire multiples together to form a pickup to cover most any arrangement of strings. reversing the coil directions between one coil and the next is how a humburcker works .
STEP 8: Last But Not Least
this little number is the guts of one of those old snooper coils that you used to be able to get at radio shack in the 70s . the idea was to attach this to the earpiece of your phone with a suction cup and you could record the conversation on an ordinary tape recorder . it wasn`t a mic that used sound waves it was a coil and magnet and picked up the signal from the wires and coils in the receiver.
STEP 9: End
i hope you all have fun trying out different coils and please be careful to use junk only and dont spoil your moms washing machine lookin for coils an stuff
any questions just ask away
lenny
lenny
140 Comments
MikeT301 5 years ago
gareth.whittock.3 9 years ago
Very interesting stuff. Thanks for posting. I wonder if you could help me. I would like to design a large pickup about 3.5 inches square, (there's a good reason trust me). Are there any design considerations I need to be aware of or should I just get a square magnet and go ahead? Thank you.
lennyb 9 years ago
if the pickup needs to be a square instead of a bar (like most are) then there are two ways to cover it one would be to wire 2 normal pickups together to get the shape (series or parralel depending on whether you want a humbucker style pickup or not)
or just wrap a single coil around your magnet .
if i were trying this i`d wrap it around a steel block and then put a powerful magnet like a hard drive magnet on the bottom afterwards. if it gets too large you may have to do more windings
Thanks for the advice. I'll let you know how I get on. Cheers, G
crazyman75 11 years ago
StingyB 9 years ago
check out an older cordless phone. all the parts you need are in there, like a pre assembled mic/pick up in the mouth end. Try two blue tooth enabled devices....if your savvy enough (like two cell phones). Or you could try a mic/pick up and a wireless jack, which transmits and receives, so your controller and robot take the place of the guitar and amp.
lennyb 11 years ago
if i see anything related to it ill pass it on though
Extremofile 10 years ago
The Q-tuner guitar and bass pickup company uses N50 neodymium bar magnets: http://www.q-tuner.com They do it for 25 years now, so it must be OK.
acdc126 13 years ago
spark light 12 years ago
LiftAndLove 10 years ago
rahmawadi 11 years ago
labernache 11 years ago
Since the two coils innermost windings are placed adjacent to each other, those windings are over the opposite poles of this special side-pole bar magnet.
According to laws set down many years ago by Scottish scientist Michael Faraday,
a coil of wire passing through a magnetic field will have an induced current that follows the right-hand rule of current flow created .
It is probably more easily demonstrated by looking up Faraday's Laws regarding magnetically induced current flow. This is the same principal that makes everything from huge generators (think Boulder Dam!), to dynamic microphones, to earbuds, to kitchen mixers, etc... work.
Faraday was an interesting person and greatly influential to modern electronics.
I hope this proves somewhat enlightening and not too wordy! ;)
lennyb 11 years ago
thank you for the clarification.
abadfart 13 years ago
freeza36 12 years ago
abadfart 12 years ago
pfred1 17 years ago
lennyb 17 years ago
