Introduction: Cheap Easy to Make Light Up Dirt Bike Stand
simple dirt bike stand with a few things to brighten the mood
Step 1: Gathering Materials
To make this Dirt bike stand you will to gather a few materials including
3/4 plywood
9 bright LED's of your color choice
some wire
9 volt battery thermal and a 9 volt battery
a switch
atleast 20 screws
3 1/4 inch square wooden dowels 11 1/2 inches long
2 13 x 5 1/2
2- Top (12 1/4) x (bottom) 15 1/4 x (top to bottom) 13 1/2
2- Top (13) x (bottom) 16 x (top to bottom) 13 1/2
Step 2: Making the Base
screw these pieces together at an angle to make a slightly angled box
Step 3: Wiring LEDS
drill 3 holes in each wooden dowel of size to fit leds
wiring the 9 leds in parallel white being positive and negative being black
glue the wooden dowels with the leds across the top of your wooden stand
Step 4: Adding Handle and Top
i cut a 4 x 3 hole in the side as a handle to make it easier to carry
add the 2 13 x 5 1/2 pieces to the top put 4 screws in each piece
Step 5: Finishing Wiring
to finish connecting your leds add a 330 ohm a switch and a 9 volt battery terminal
Make It Glow! Contest
