Cheap N' Easy Stage Sword
Intro: Cheap N' Easy Stage Sword
lets face it, swords are cool, expensive, and hard to make. so, with a 6$ piece of weldabul steel,(take a note of this, Watson) a thin brass rod, a wood dowel, and a mind full of sharp and pointy objects, i set out on my quest for over-sized letter openers.
STEP 1: Stuff You Need
like i said,you need a Piece of 1/16 inch weldable steel (the width that you want your sword.) A dowel that fits in your hand comfortably, A 1/16 inch bras rod, A 6 by 1 inch Piece of 1/16 inch steel For the hilt.
STEP 2: What to Do
sand the paint, rust, and edge off your blade.then cut the end how you want it to be.t
STEP 3: Make the Tang
hen cut the dowel in half.hold one half of the dowel on each side of the blade, then Trim the blade so the dowels are flush.
STEP 4: Make the Hilt
drill two 1/16 inch holes through the dowels and the Blade. then pound the rod through the holes and sand it flush.Flush.take the little hilt piece and drill several 1/16 inch holes rite next to each other, until you can tightly slide it down Your blade. then weld, solder or glue the hilt on.
STEP 5: Have Fun!
now give it to the biggest D&D nut in town, or your son! (that's what i did!) its not a real sword, so its safe for kids.
3 Comments
bendog38 14 years ago
You don't have any of your own pictures, do you?
joerubberboots9 14 years ago
Mr. tony stark 11 years ago
