Cleaning Longboard Bearings
Intro: Cleaning Longboard Bearings
you wil need:
- aceton
- cleaning kit
- grease
- dirty bearings
- rags
- aceton
- cleaning kit
- grease
- dirty bearings
- rags
STEP 1:
taken out the rubber ore steel protective cap of by using a needle ore paperclip.
STEP 2:
put the bearings on the rod with a spacer between every bearing and put the screw on the end (make Sure the steel balls Are facing upwards).
fill the bottle 1/3th
STEP 3: Shake It Off!
put the lid on top and shake for 30 seconds.
refresh the aceton en repeat until the aceton comes out clean.
STEP 4: Drying and Oiling
dry your bearings and If you want use compressed air to blow out any residue.
put two drips of oil on the steel balls and give it a spin.
STEP 5: Reassembling
put the caps back on and your doen!
amberrayh 9 years ago
Thanks for sharing these clear instructions!
