88Views7Replies
Author Options:
10w led on motorcycle Answered
I have 3 10w led lights on my motorcycle, but they burning out in time. I guess its because 12v/11A sums up way beyond 10w? Is there some  easy solution, like resistors or diodes ?
Jack A Lopez
Jack A Lopez
Best Answer 4 years ago
I suggest using a constant current source, i.e. a driver circuit for to regulate the current to your LEDs and keep that current constant. That way you actually know how much current (and power) is going to your LEDs, and you will be less likely to overpower them.
Yonatan24
Yonatan24
4 years ago
Are they getting actual 12V?
Are they attached to a heatsink with thermal paste/adhesive?
SamaelsL
SamaelsL
Answer 4 years ago
yes, they are 12v and attached to heatsink, problem is, that fully charged battery holds over 13v and even more when generator kicks in
Yonatan24
Yonatan24
Answer 4 years ago
That explainjs everything. Lower the voltage!
petercd
petercd
4 years ago
I guess its because your bike is actually delivering 14V + instead of 12V, and you most likely dont have a proper constant current driver for the leds.
Downunder35m
Downunder35m
4 years ago
I don't know of any legal way to use 10W LED lights on a motorcycle, so I assume that is the main cause of failure - not designed for the task.
degrooty
degrooty
4 years ago
Can you post a picture?
