25906Views42Replies
Author Options:
12v battery low voltage disconnect with relay? Answered
Could i make 12v battery low voltage disconnect with relay and resistor?
I was thinking if put resistor in series with relay coil i could lower current so relay would barely work on 12v but when it drops to 10v voltage after resistor would be so small that relay would disconnect
iceng
iceng
Best Answer 4 years ago
A 10Vz or 9Vz Zener Diode supplies 5 ma to an NPN 2N2222 1A, Hfe=100 gain transistor which drives 150 ma relay at 12 VDC but Drops out when the supply goes below the Zener voltage.
sujinwilliam
sujinwilliam
Reply 1 year ago
Low voltage cutoff is working on 12. 7volt
How to set 10.6
sujinwilliam
sujinwilliam
Reply 1 year ago
I'm use this circuit. But low cutoff is working on 12. 79v
aryajaya
aryajaya
Answer 4 years ago
where is the Input and Output terminal?
help me please.
iceng
iceng
Answer 4 years ago
Please make the effort to click the pics to see the whole image !!!!
MahiM7
MahiM7
Answer 2 years ago
awesome ckt, thx from Bangladeshi......
aryajaya
aryajaya
Answer 4 years ago
already try it. Use zener 11v and it will disconnected at 2.5v, not 11v????
iceng
iceng
Answer 4 years ago
Hard to verify the wiring from your picture and there is no relay which explains the PM "let me know for relay connection coil, where is the positive and ground connection terminal"
If it disconnects at 2.5v how are you detecting that ?
The transistor needs a load use another 4.7K resistor in place of the relay coil...Then the when the voltage across the resistor drops to zero or the voltage of the transistor with respect to GND = ground goes to the supply voltage..
You can assume the transistor is turned OFF and any 12v relay coil (has_no_positive_terminal) will release the contacts to the No_Power position.. That is the position the relay has when taken out of the shipping container as determined with an ohmeter..
BTW, how are you reducing the voltage from 12.4v to 11v ?
If the voltage has a momentary voltage drop the full relay ckt will lock out..
aryajaya
aryajaya
Answer 4 years ago
i use step down module for test the schema. Let me try to take picture of the wiring.
iceng
iceng
Answer 4 years ago
You do take nice clear pictures..
I think I see the relay is the dark blue blob on the right..
I assume you test by starting over 12 v and slowly lower the analog voltage (NO_PWM) !
Add an LED and a resistor to indicate when the relay is ON/off...
As usual click the pic to see the entire circuit image..
aryajaya
aryajaya
Answer 4 years ago
now it work. Cut off on 10.9v. But have another problem. When I cut off on 11.4v, this circuit not working. But when i charge battery on 12v, it working again.
Any solution for this situation?
iceng
iceng
Answer 4 years ago
The circuit has hysteresis, that means you need to get it back into a higher voltage. Hysteresis is important to prevent oscillation....
After all this simple circuit was designed as a battery cut out only....
Add a momentary push button across the zener to restart the relay if you want...
JoseMI99
JoseMI99
Answer 3 years ago
Hi iceng, I
am implementing this circuit with a 22Vz Zener to cut-off two serial 12v lead
batteries.
The circuit
responds cutting-off when the voltage of the batteries goes below 22v and
rearms at around 23V (actually the batteries serial voltage is around 24V as I
have 3 power diodes in series with the input, which reduce the measured voltage
at the Zener in 2V approx.).
How could I
increase the hysteresis? I would like to make this circuit rearm only after the
batteries serial voltage is above 25V.
My problem
is the type of charge I am connecting, as it commands a motor and the voltage
read at the Zener goes down when the motor is turning fast, so the relay
cuts-off, but as the power is not any more feeding the motor, the voltage read
at the Zener goes again up enough to re-activate the relay, so the motor
continues turning while the relay is very fast switching between on and off.
I would be
very glad if you or somebody else could put some idea or tip on how to increase
the hysteresis of this circuit.
Thanks in
advance
Jose
JoseMI99
JoseMI99
Answer 3 years ago
Sorry for the strange order of the comment, I copied it from a word and I cannot correct it after several trials..
aryajaya
aryajaya
Answer 4 years ago
across zener mean paralel with zener?
iceng
iceng
Answer 4 years ago
Yes parallel :-)
aryajaya
aryajaya
Answer 4 years ago
i know now. It need some short connection for reset.
This is the final board but not with reset button, change resistor value to find some cut off voltage, maybe will be good use VR to adjust the cut off voltage. this circuit Will be use for BOOMBOX portable MP5 and bluetooth Speaker.
Regards.
aryajaya
aryajaya
Answer 4 years ago
will test it with SLA battery.
aryajaya
aryajaya
Answer 4 years ago
or can it try with adjustable DC power supply?
iceng
iceng
Answer 4 years ago
YES !
aryajaya
aryajaya
Answer 4 years ago
here the pic
aryajaya
aryajaya
Answer 4 years ago
thanks.
One more time, if i want disconnected for 11v, what component i must replace?
aryajaya
aryajaya
Answer 4 years ago
thanks ......
MuhammadQ29
MuhammadQ29
Answer 3 years ago
11.5 vdc low cutt off this schematic 10vz replaced 11.5vz
iceng
iceng
Answer 3 years ago
Yes True
Cekpi7
Cekpi7
Answer 4 years ago
I will try to do this since it requires few parts
milad75
milad75
1 year ago
I'm trying to build this circuit, but my relay is ALQ324 and has only 4 pins. I have two pins for the coil and two other pins. My question is how do I need to only connect to those two pins of relay or all four pins has to be connected?
ur answer is appreciated.
sujinwilliam
sujinwilliam
1 year ago
Cut off is working on 12. 8v
How to set 10.6
Cekpi7
Cekpi7
Reply 1 year ago
Cut off voltage is set by zener diode, check voltage on diode. Also check voltage on 4.7K resistor
mbdmbd
mbdmbd
2 years ago
Thanks to everyone who has contributed to this thread. I have built one of these to protect a lead acid battery from being trashed by a buck converter that would otherwise run forever.
My remaining problem is that I occasionally get conditions in the load that pull down the voltage below the protection level for approx 1 second. I assume that the relay can be kept energised temporarily by addition of a capacitor... but I am a Software engineer with only a few scraps of Electronics, so 1) I would appreciate a hint as to where to put it (I am guessing across the poles of the relay coil - and since it'll be an electrolytic cap, - respecting the polarity of the existing circuit).
2) Any suggestions as to the size of the cap would be useful. The voltage drop is of the order of 4v and the current through the relay coil is probably in the order of 20mA..... oh, if only I had a storage 'scope, this would be a breeze.
Thanks in advance.
Ba_eji
Ba_eji
3 years ago
Lvd circuit diagram. @iceng, kudos to you. Could u pls send me the circuit diagram for the 12v battery low voltage shut off.
aryajaya
aryajaya
4 years ago
use this for my DIY boombox speaker.
Use reset button, thanks.
IMG_20170304_082811.jpgIMG_20170304_144851.jpgIMG_20170304_144909.jpgIMG_20170304_145003.jpg
Cekpi7
Cekpi7
Answer 4 years ago
woah, i forgot about this project, nice man
You used schematic that iceng posted? I guess its time for me to go back to making this
aryajaya
aryajaya
Answer 4 years ago
yes. Use iceng circuit.
Cekpi7
Cekpi7
Answer 4 years ago
I want to make portable power pack that would be protected so i cant damage it
I would use 2x12v batteries since i have 2 sla laying around
Cekpi7
Cekpi7
Answer 4 years ago
Im gonna try to do that
iceng
iceng
Answer 4 years ago
Nice find.
iceng
iceng
4 years ago
Most relays do have a higher pull-in voltage and a lower drop-out voltage.
Downunder35m
Downunder35m
4 years ago
Since you need the power cut when the battery is low and then charge it you have several options available:
1. Simple battery monitor - it disconnects the load once a critical low voltage is reached, the other guys linked some already.
2. A dedicated battery isolator as used in 4WD and campers - they work fully automatic, if the input voltage is high enough they allow to charge the battery otherwise they block this way, once battery is going however they won't protect the output and shut off. IMHO only really good with two batteries.
3. Better than 1 and more versatile is a solar charge controller. They do exactly what you want and offer a dedicated charging circuit so you connect a proper DC source of 15 to 24V and the battery will be charger, plus it all works as well while charging.
