320Views3Replies
Author Options:
2 stroke motor help? Answered
Hi guys I built something similar to this https://www.instructables.com/id/How_to_Strap_a_Leaf_Blower_Engine_to_a_Bike_and_Go/ anyways the coil thingy that the guy cut a circular hole for came off my engine. There's magnets in it. I'm pretty sure that the magnets drive the spark plug as there's a small black piece that hooks to the plug. So am I screwed?
cerberustugowar
cerberustugowar
8 years ago
if you are looking to set the air gap on between the ignition coil and the flywheel magnet, use a business card as a general setting. Without knowing your engine make, model, code there is no way to tell the exact air gap. I still use this method at work when there is no service manual to follow. Just make sure when you put in the business card that the metal legs off of the coil are on top of the magnet for the flywheel or you may run into clearance problems when you actually try to run the unit.
nurdee1
nurdee1
9 years ago
I agree with Wesley666 but I always use a dollar bill instead of a iece of cardboard. I also might sugest getting a book about two stroke engines from your library. Or you could just go online.
BIGHAIRYDUDE
BIGHAIRYDUDE
10 years ago
screw it back on it is the ignition coil you need to have it there of there will be no spark. will it go back on?
