10696Views4Replies
Author Options:
230V 3 Phase Motor on 240V Single Phase Supply Answered
Hi,
I am a ME with very limited knowledge on electrical side of the world.
I have ordered a electric motor from Germany with 240 V assuming it will be single phase.
The motor has rocked up with 230 V winding but 3phase connections.
Is there any chance I can connect this motor to our single phase supply???
Any device which will help to use this motor.
Please help.
Tags:Motor
iceng
iceng
5 years ago
Just to see what all those connections mean.
Do note, that because of the inaccessible internal connection you cannot use a Delta motor winding.
Josehf Murchison
Josehf Murchison
5 years ago
Where do you live?
10 volts is nothing service can vary by 20 volts.
Some 3 phase motors have 2 wire and 3 wire connection diagrams ether on the maker plate or under the connection box plate.
Open the connection box and see if it has 3, 6, 9, or 12 wires.
3 wires is fixed forward.
6 and up wires is reversible and may be able to convert from a 3 phase line to a 2 phase line depending on where you live.
iceng
iceng
5 years ago
A friend wound a single phase machine that can best be defined as a phase adder.
Normally the military uses MG (motor=generator) sets.
The phase adder has extra internal winding's which add the two more time displaced phases that let you power your 3-phase motor at the exact frequency.
rickharris
rickharris
5 years ago
you will however lose some power.
