127Views4Replies
Author Options:
30 minute DIY AM particle-acceleration Answered
Last fall, I verified an initial relationship of resonance between two bifilar wound wires (of any length).
The predictable sequence resonates at the following levels - 20 Hz, 30 Hz, 50 Hz (and all multiples of these 3 frequencies).
I used a Parallax Propeller Board - with PGEN 2.0 software from Innovationshop in Germany.   This software allows for a waveform built of 32 stacked frequencies to be created and amplified.
I have used it to successfully break the bonds of distilled water - as one of my earlier videos shows 2 years ago.
JL Naudin calls it a "GEGENE machine" - but it is a simple, tabletop, particle accelerator.
His results can be found here:::
http://jnaudin.free.fr/wfcbooster/indexen.htm
One of my earlier videos from May 2013 - can be found at YouTube - I just want to show people how this works.  It is a 4 minute explanation of open-sourced Patent 512,340.:::
https://www.youtube.com/watch?v=HHxK1VWrXcM
The materials::
1 - 1800 watt induction cooktop (iron, copper, or 3-ply stainless cookware is required on these types of devices)
2.  50 feet of 14 AWG speaker wire
3.  2-10 count of 500-watt halogen lightbulbs.
4.  wire, solder & connectors for the wire-ends.
5.  1 stainless-steel HHO DC electrolyzer tank.
6.  Cooking Pan - or light fixture (to hold light bulbs).
7.  High Voltage diodes (500 Volts or higher)
Kiteman
Kiteman
6 years ago
Um... there's no particle accelerator there, just a transformer being used to light some bulbs and electrolyse some water.
jabel4
jabel4
Reply 6 years ago
You will need the patent - then. Because you are incorrect - sir.
Also, AM modulated cooktops won't stay energized - unless a resonant state exists. It would shut off at 8 seconds. Mine can go for hours - using distilled water - and patent 512,340 sitting on top.
Enjoy.
PATENT # 512,340.
Kiteman
Kiteman
Reply 6 years ago
I don't need a patent to be able to interpret what I see.
The wire coil allows the induction hob to run. The hob's oscillating field induces a current in the coil, that current lights the bulbs and splits the water.
The nearest you get to a "particle accelerator" is the electrons being pushed around the coil by the hob's magnetic field.
(I do hope you aren't going to claim that the electrolysis set-up runs the hob...)
jabel4
jabel4
6 years ago
I forgot #8 & #9 & #10 & #11
8. Super-Glue - or any other fast-drying plastic-to-plastic adhesive.
9 Watt-Meter (using a "Kill-o-Watt" for $20 from the local hardware store).
10. 120 volt power source
11. Primer plate (1 piece of induction cookware, or small sheet of magnetic stainless steel.
