91Views5Replies
Author Options:
4-DCMotor Driver? Answered
please
help me to connect 4-DC-Motor-Driver-Module to arduino
thank you
steveastrouk
steveastrouk
3 years ago
Erm. WHAT motor driver ? Where did it come from ? What chips does it use ? Have you got mating connectors for the white signal lines.
rickharris
rickharris
Answer 3 years ago
The 2 chips are L293D's so the cct will look something like the illustration below (click for full size) cct from http://www.picaxe.com/ interface manual.
You should be able to work out or find out with a meter which connection goes where.
Each L293D will drive 2 DC motors BUT current is limited to 600 mA for each output.
iceng
iceng
Answer 3 years ago
While the 293D is designed for 4v to 36volts, that driver PCB looks like a 12V design..
rickharris
rickharris
Answer 3 years ago
It can be the control voltage can be separated from the drive voltage. My diagram shows them both at 5 volts.
http://www.ti.com/lit/ds/symlink/l293.pdf
the data sheet shows that pin 8 can be connected to 4.5 to 36 volts for drive voltage.
the only real issue with the IC is the 600 mA current for each output. A lot of even small DC motors draw more under start up and stall the chip.
iceng
iceng
Answer 3 years ago
Yes, they the motors do draw more at start and at load.
The reasoning for 12v board is the profusion of 16v DC capacitors
I see on the PCB
Downunder35m
Downunder35m
3 years ago
I would thin wires if you don't have the right plugs and breakout wires.
