71356Views14Replies
Author Options:
4 wires fan to 2 wire Answered
Hi guys, i need your help!
I have an Enermax 12cm fan (EB122512H), i need to plug it to a 12v DC power supply but i don't know how to wire it;
The fan has 4 wires (yellow, black, white, red) but the power supply has just two wires.
could you help me?
matt.baker483
matt.baker483
1 year ago
On these 4 wire computer fans i have found that some times they require an input to tell it how fast to spin so simply supplying power to 2 of the wires will not work if you have a 3 wire fan however you can supply power to the red and black and leave the white disconnected
EricF172
EricF172
2 years ago
This is an exhaust fan of a Lenovo E49. I am confused which 2 wireshave to be connected to the battery to give power. Plz answer ASAP
Jarnsaxa
Jarnsaxa
4 years ago
Google brought me here. I found the same fan in some old broken PSU. Did not work at first, but don't give up yet fellows :-)
Yellow +12V
Black GND
White rotation sensor
Red PWM input
Since this product is not meant to be replaced with standard components, Enermax omitted the pull-up resistor on the PWM input. Simply connect Yellow and Red to +12V and the fan will run.
MichelS7
MichelS7
5 years ago
i have tried all the possible configurations but it doesn't work :\ when i try black and red the fan moves a bit for a tiny instant but it stops immediately.... i think it is broken because it starts to stink like a burnt circuit
Jack A Lopez
Jack A Lopez
Answer 5 years ago
That smell might be the smell of magic smoke,
https://en.wikipedia.org/wiki/Magic_smoke
There's not much the Answers forum can do for you if your fan has released its magic smoke. ;-)
If this is the case, I am hopeful you will find another fan, and hook that one up correctly next time.
Jack A Lopez
Jack A Lopez
Answer 5 years ago
Here is a project idea for broken PC fan. Assuming the windings and magnets are still good, you can make a very tiny alternator generator.
https://www.instructables.com/id/Old-PC-Fan-Wind-Tu...
That is, if you can take the fan apart without breaking it, and also manage to rewire, de-solder, re-solder, the stuff connected to the fan's windings.
MichelS7
MichelS7
Answer 5 years ago
thanks =)
Jack A Lopez
Jack A Lopez
5 years ago
I think that might be a PWM fan, and this page,
http://www.pavouk.org/hw/fan/en_fan4wire.html
sort of explains the pinouts for this kind of fan. The four wires are: ground, +12V, PWM input, and speed sense output.
I think if you can figure out which two wires are ground and +12V, and leave the other wires open, i.e. not connected, then the fan will turn at full speed.
seandogue
seandogue
Answer 5 years ago
If I had bothered reading the comments I woudl ahve seens yours and moved on
+1
seandogue
seandogue
5 years ago
Can't sake with 100% assurance, but see
http://www.kitguru.net/components/power-supplies/z...
For an interesting tidbit.
"The 120mm Enermax branded fan (EB122512H) is controlled to rotate between 450 rpm and 2,000 rpm depending on the ambient temperatures. It is a 9 blade design and incorporates dual ball bearing and is rated for 0.30A at 12V."
It could be the two extra wires are for measuring fan speed (my fav) controlling speed, or it could be a stepper (although that seems overkill for a power supply fan)
sure enough...a quick search of google images for Enermax EB122512H presents this "insitu" image, which answers it handily:
iceng
iceng
5 years ago
Use +red and -black.
Downunder35m
Downunder35m
5 years ago
Yellow on +12V
Black on Ground
I suspect the other two are for spped control/light.
MichelS7
MichelS7
Answer 5 years ago
if i just use the yellow and the black, the fan doesn't run... is it possible to bypass the speed control?
Downunder35m
Downunder35m
Answer 5 years ago
Hmmm, unusal but try red and black.
Would mean Yellow is used for the speed sensing.
iceng
iceng
Answer 5 years ago
+1
